73 filler neck gasket...1 or 2? |
914xr75 |
Oct 14 2018, 02:28 PM
Member Group: Members Posts: 174 Joined: 24-March 18 From: Whittier, CA Member No.: 21,996 Region Association: Southern California |
bdstone914 |
Oct 15 2018, 05:26 AM
bdstone914 Group: Members Posts: 4,536 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
If the leak is from the filler neck you shoul see some stains around the tank in that area.
That tank should have a metal expansion tank and has a visible metal filler neck. Only the 75-76 tanks had a one piece plastic expansion and filler neck. You will smell gas fumes unless you replace the evap system. You are missing the expansion tank, charcoal canister with hold down clamp and all the hoses that go with them. You can reinstall the evap system with carbs. If you decide to replace the system I have the parts. You would need new hoses. Bruce |
Lo-Fi Version | Time is now: 9th June 2024 - 02:11 AM |
