> Self loosening axle bolts-will spring waters take care of this?
Tdskip
post Oct 15 2018, 07:06 AM
Good morning-hope everybody had a good weekend.
It would seem as if one of the rights of 914 ownership passages is dealing with self-loosening axle bolts.
Will the correct size spring washers from Ace deal with this, or do I need special serrated ones, or do I need to safety wire them?
Thanks in advance for the help, have a good morning.
Larmo63
post Oct 15 2018, 09:56 PM
I'm pretty sure 914 Rubber sells the correct drilled ones.....?
Tdskip   Self loosening axle bolts-will spring waters take care of this?   Oct 15 2018, 07:06 AM
TheCabinetmaker   New Schnoor washers and proper torque will keep th...   Oct 15 2018, 07:38 AM
mepstein   New Schnoor washers and proper torque will keep t...   Oct 15 2018, 07:40 AM
VaccaRabite   Yes the new Schnoor washers and clean threads, but...   Oct 15 2018, 07:55 AM
wndsrfr   Yes the new Schnoor washers and clean threads, bu...   Oct 15 2018, 08:00 AM
Tdskip   Thanks Gentlemen   Oct 15 2018, 08:08 AM
914forme   I do that, and then safety wire them. That works ...   Oct 15 2018, 05:06 PM
Tdskip   Pulled one to go make sure I get the right size wa...   Oct 15 2018, 07:49 PM
jcd914   Pulled one to go make sure I get the right size w...   Oct 15 2018, 08:00 PM
914sgofast2   It’s the wrong bolt for the CV joints. They are ...   Oct 15 2018, 08:05 PM
Mark Henry   That's not a factory bolt or washer.   Oct 15 2018, 07:56 PM
SirAndy   That bolt doesn't look right, also, the center...   Oct 15 2018, 07:57 PM
Mark Henry   That bolt doesn't look right, also, the cente...   Oct 15 2018, 08:06 PM
914_teener   Go buy a lottery ticket if you had that on the fre...   Oct 15 2018, 09:37 PM
Larmo63   I'm pretty sure 914 Rubber sells the correct d...   Oct 15 2018, 09:56 PM
wndsrfr   I'm pretty sure 914 Rubber sells the correct ...   Oct 16 2018, 06:05 AM
Mikey914   Yep https://shop.914rubber.com/914-CV-bolt-dril.....   Oct 15 2018, 10:06 PM
burton73   Yep https://shop.914rubber.com/914-CV-bolt-dril....   Oct 16 2018, 09:44 AM
pete000   Rebuilding my CV joints and noticed my car was mis...   Oct 15 2018, 10:18 PM
RenoRoger   Rebuilding my CV joints and noticed my car was mi...   Oct 16 2018, 03:21 AM
porschetub   Rebuilding my CV joints and noticed my car was m...   Oct 16 2018, 01:10 PM
IronHillRestorations   The Schnoor washers are a one and done part, which...   Oct 16 2018, 06:22 AM
mskala   IMO, if you use _new_ schnorr washers each time, t...   Oct 16 2018, 06:58 AM
Bartlett 914   I have said this and I will say it again. When the...   Oct 16 2018, 09:22 AM
TravisNeff   I bought a big bag of the schnorr washer from McMa...   Oct 16 2018, 02:05 PM
Jeff Hail   Good morning-hope everybody had a good weekend. ...   Oct 16 2018, 06:45 PM
jfort   My notes to myself: Axle bolts: 6mm Allen (after ...   Oct 16 2018, 06:59 PM
jim_hoyland   Nice info here on Schnoor washers:. https://schnor...   Oct 16 2018, 07:43 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 10:40 AM
