| Tdskip |
Oct 15 2018, 07:06 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,755 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None
Good morning-hope everybody had a good weekend.
It would seem as if one of the rights of 914 ownership passages is dealing with self-loosening axle bolts. Will the correct size spring washers from Ace deal with this, or do I need special serrated ones, or do I need to safety wire them? Thanks in advance for the help, have a good morning. |
| mskala |
Oct 16 2018, 06:58 AM
R ![]() ![]() ![]() Group: Members Posts: 1,942 Joined: 2-January 03 From: Massachusetts Member No.: 79 Region Association: None
IMO, if you use _new_ schnorr washers each time, then having grease-free threads
is not necessary. I've installed and removed a bunch of times, I could never get the area clean while still having grease everywhere you need it. I've checked the torque before each autocross, they have never loosened even a little. |
Tdskip Self loosening axle bolts-will spring waters take care of this? Oct 15 2018, 07:06 AM
TheCabinetmaker New Schnoor washers and proper torque will keep th... Oct 15 2018, 07:38 AM
New Schnoor washers and proper torque will keep t... Oct 15 2018, 07:40 AM
VaccaRabite Yes the new Schnoor washers and clean threads, but... Oct 15 2018, 07:55 AM
wndsrfr
Yes the new Schnoor washers and clean threads, bu... Oct 15 2018, 08:00 AM
Tdskip Thanks Gentlemen Oct 15 2018, 08:08 AM
914forme I do that, and then safety wire them. That works ... Oct 15 2018, 05:06 PM
Tdskip Pulled one to go make sure I get the right size wa... Oct 15 2018, 07:49 PM
jcd914
Pulled one to go make sure I get the right size w... Oct 15 2018, 08:00 PM
914sgofast2 It’s the wrong bolt for the CV joints. They are ... Oct 15 2018, 08:05 PM
Mark Henry That's not a factory bolt or washer. Oct 15 2018, 07:56 PM
SirAndy That bolt doesn't look right, also, the center... Oct 15 2018, 07:57 PM
Mark Henry
That bolt doesn't look right, also, the cente... Oct 15 2018, 08:06 PM
914_teener Go buy a lottery ticket if you had that on the fre... Oct 15 2018, 09:37 PM
Larmo63 I'm pretty sure 914 Rubber sells the correct d... Oct 15 2018, 09:56 PM
wndsrfr
I'm pretty sure 914 Rubber sells the correct ... Oct 16 2018, 06:05 AM
Mikey914 Yep
https://shop.914rubber.com/914-CV-bolt-dril..... Oct 15 2018, 10:06 PM
burton73
Yep
https://shop.914rubber.com/914-CV-bolt-dril.... Oct 16 2018, 09:44 AM
pete000 Rebuilding my CV joints and noticed my car was mis... Oct 15 2018, 10:18 PM
RenoRoger
Rebuilding my CV joints and noticed my car was mi... Oct 16 2018, 03:21 AM
porschetub
Rebuilding my CV joints and noticed my car was m... Oct 16 2018, 01:10 PM
IronHillRestorations The Schnoor washers are a one and done part, which... Oct 16 2018, 06:22 AM
Bartlett 914 I have said this and I will say it again. When the... Oct 16 2018, 09:22 AM
TravisNeff I bought a big bag of the schnorr washer from McMa... Oct 16 2018, 02:05 PM
Jeff Hail
... Oct 16 2018, 06:45 PM
jfort My notes to myself:
Axle bolts: 6mm Allen (after ... Oct 16 2018, 06:59 PM
jim_hoyland Nice info here on Schnoor washers:. https://schnor... Oct 16 2018, 07:43 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 10:42 AM |
