Lift Tips, do's & don'ts / tips & tricks since owning a lift |
76-914 |
Sep 24 2018, 11:06 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,509 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
I've owned my lift for 2 years come November and along the way I've found a few things worth sharing. Feel free to add your own tips here especially if they involve safety.
1) I took almost a year to realize that I wouldn't be upright under my car while working like you see in the advertisements. Oh sure, I do some work upright but for the most part it is very uncomfortable and results in a stiff neck. So, raised appx 2' I use my creeper as it is much more comfortable to work while laying than upright. 2) It was another year before I learned that the best benefit of having this lift was to raise the car appx 2ft off the ground so I don't need to bend over for hours at a time resulting in a back ache. 3) Clear the area below before lowering your lift. Twice! 4) Clear the area above before raising. 5) Jack Extensions - My MaxJax comes with 4" lift extensions to give you a little more headroom however these can't be fitted beneath the 914 because it sits so low. I need to lift it a few inch's with the lift then lower it upon blocks. Only then is there enough room to insert the extensions. I can't use wood blocks under the longs to hold it higher because I have fiberglass valance covers. So I placed blocks beneath the wheels instead. This doesn't work worth a Continental Damn because of the 914's suspension. As I lowered the car it would walk to the side if the fronts touched ground 1st of it would walk forward if I'd left the Ebrake on or left it in gear. A couple of times I thought the tire would slip off one of the blocks as it was lowered. I cured that yesterday. HF had the 12"x18" furniture dollies on sale for $7 so I now have 4 of those to place beneath the wheels when using the extensions. Cheaper than the purpose made dollies that sell for about $40 each and rated at 1000 lbs. Much safer now. 6) Don't leave your car on the lift unnecessarily especially if you live in Earth Quake regions. 7) Use the lift's safety catch's or safety lock outs. (IMG:style_emoticons/default/beerchug.gif) |
michael7810 |
Oct 20 2018, 05:40 PM
Senior Member Group: Members Posts: 1,081 Joined: 6-June 11 From: Scottsdale, AZ Member No.: 13,164 Region Association: Southwest Region |
rgolia |
Oct 21 2018, 03:30 AM
GeoJoe Group: Members Posts: 705 Joined: 5-February 10 From: PA Member No.: 11,329 Region Association: North East States |
I have a mid rise and didn’t realize how great it was until I got this With a flat creeper I could only raise the car 12” or it was too high to work on. Now I can raise it 30” and comfortably work. I have the same and it is great. Head clears the bottom of the car without the extensions in place. I have a rolling tool tray so things don’t roll around on the floor. |
Lo-Fi Version | Time is now: 9th June 2024 - 07:36 AM |
