| dmilzoff |
May 19 2003, 04:52 PM
Member ![]() ![]() Group: Members Posts: 67 Joined: 2-March 03 From: Ossining, NY Member No.: 377 |
I have a 1970 914-6 with a low pitched pulsing hum. It only happens when I make a slow right turn at low speed (at high speeds the engine may obscure the noise.) It seems to be the front right wheel. The tire has plenty of clearance. Tie rod? Wheel bearings? Any ideas on a way to track down the cause and solution?
| Gint |
May 19 2003, 05:00 PM
Mike Ginter ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,106 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
Step on the go/loud pedal and forget about it.
Sorry. I'm sure your serious. Jack the front of the car up and grab the wheel(s) at noon and 6 and check for loose wheel bearings. Grab at 3 and 9 and wiggle to check for tie rod play. Take a pal out there and have him/her move a wheel right to left and check the steering shaft and rack for movement. This little exploratory should give you a better idea what's wrong. Or at least give us a better idea of what it may be based on your results. |
Lo-Fi Version | Time is now: 4th March 2026 - 07:42 PM |
