> What Motor and Transmission mounts to use, What motor and transmission mounts to use
Ken Mikos
post Oct 28 2018, 07:32 PM
Replacing motor and transmission mounts in a original 1973 1.7. Any suggestion on the type and where to purchase? Thanks,
Ken
UROpartsman
post Oct 29 2018, 10:51 AM
For a '73-'76, engine mount 039 199 231 is common and available from many sources.
There are two transmission mount choices:
914 375 025 00 is the 4-cyl mount and has some voids in the rubber to allow some movement. This is also the engine mount for '70-'72.
914 375 026 00 is the 6-cyl mount and is solid rubber. This mount is considered a stiffer "sport" version when used on 4-cyl cars.
Note regarding use of modified 911 engine mounts as 914 transmission mounts:
When modified to be used as 914 transmission mounts, 911 engine mounts require the mounting holes in the ears to be filed into an oval shape or re-drilled, do not have the proper anti-rotation pins on the center sleeve, are close but not quite the same thickness, are not the original stiffness (the engine mounts are stiffer), and do not have the same appearance as original 914 transmission mounts, which can be an aesthetic issue in a fully-restored vehicle. However, modified 911 engine mounts were certainly a functional substitute until proper 914 transmission mounts were finally made available again from URO and Porsche OEM. (Edited for clarity 11/1/18.)
Ken Mikos   What Motor and Transmission mounts to use   Oct 28 2018, 07:32 PM
Dave_Darling   The 73 uses solid outboard mounts between the bar ...   Oct 28 2018, 08:22 PM
914Sixer   Buy stock and be done.   Oct 29 2018, 07:46 AM
UROpartsman   For a '73-'76, engine mount 039 199 231 is...   Oct 29 2018, 10:51 AM
DRPHIL914   For transmission most of us have been using the 91...   Oct 29 2018, 11:00 AM
troth   Very happy with my wevo semi-solid trans mounts. K...   Oct 29 2018, 11:01 AM
DRPHIL914   Very happy with my wevo semi-solid trans mounts. ...   Oct 29 2018, 11:24 AM
troth   Very happy with my wevo semi-solid trans mounts....   Oct 29 2018, 12:08 PM
DRPHIL914   here is a picture of a 911 motor mount used on the...   Oct 29 2018, 11:02 AM
DRPHIL914   stock motor mount   Oct 29 2018, 11:08 AM
Ken Mikos   Thanks for all the follow up. You guys are a great...   Oct 29 2018, 02:52 PM
GregAmy   What's the right combo for a '74 track-onl...   Oct 31 2018, 06:44 AM
pete000   I have been running the Wevo blue Trans mounts fo...   Oct 31 2018, 10:00 AM
Dave_Darling   For a track-only car? Solid all the way around. ...   Oct 31 2018, 12:05 PM
sithot   I seem to recall some kind of issue with Webers ...   Oct 31 2018, 08:14 PM
GregAmy   For a track-only car? Solid all the way around. ...   Nov 1 2018, 07:54 AM
GregAmy   For a track-only car? Solid all the way around....   Nov 4 2018, 12:04 PM
GregAmy   "Solid" as in aluminum-solid? I don...   Oct 31 2018, 12:18 PM
Literati914   *Modified 911 mounts do not have the proper anti...   Oct 31 2018, 06:09 PM
UROpartsman   So, are you saying that either of the engine mount...   Nov 1 2018, 09:53 AM
GeorgeRud   I think either the 914-6, 911, or WEVO mounts will...   Oct 31 2018, 06:39 PM
Literati914   I think either the 914-6, 911, or WEVO mounts wil...   Oct 31 2018, 07:49 PM
mepstein   [quote name='GeorgeRud' post='2661903' date='Oct ...   Oct 31 2018, 07:52 PM
DRPHIL914   [quote name='GeorgeRud' post='2661903' date='Oct ...   Oct 31 2018, 08:03 PM
Larmo63   I'm going to change out my solid aluminum/delr...   Oct 31 2018, 10:27 PM
ConeDodger   I was seduced early on by solid mounts. My car is ...   Nov 1 2018, 08:28 AM
Dave_Darling   My contention is that on a race car, you nut-and-b...   Nov 4 2018, 01:45 PM
GregAmy   Thank you, Dave, I appreciate the advice.   Nov 4 2018, 03:48 PM
Ken Mikos   First drive today after installation of New Motor ...   Mar 17 2019, 07:18 PM
UROpartsman   Excellent Ken, which motor and transmission mounts...   Mar 18 2019, 11:11 AM
Ken Mikos   Excellent Ken, which motor and transmission mount...   Mar 18 2019, 02:39 PM
- Lo-Fi Version Time is now: 4th March 2026 - 09:16 PM
