Value of a 7R case? |
Wegeng_Haus |
Oct 29 2018, 05:23 AM
Newbie Group: Members Posts: 38 Joined: 10-December 11 From: Champaign Illinois Member No.: 13,881 Region Association: Upper MidWest |
I'm looking for opinions on the value of a 7R 911 engine case, fully machined and Case Savers installed by Ollie's? Thanks. (IMG:style_emoticons/default/icon_bump.gif) (IMG:style_emoticons/default/confused24.gif)
Larmo63 |
Oct 31 2018, 09:53 AM
Advanced Member Group: Members Posts: 4,264 Joined: 3-March 14 From: San Clemente, Ca Member No.: 17,068 Region Association: Southern California |
The completely rebuilt engine I bought as a 2.7 for my conversion was found through an ad in the back of Panorama.
I made the deal over the phone, it shipped and I went to work on getting the car prepped for it; motor mounts, oil tank install, oil cooler, etc. When we decided to bore out the heads and manifolds from 32mm to 36mm, we discovered that the pistons were 83.9mm so 2.4 displacement. At first, I was a bit pissed that it wasn't the 2.7 I thought I had bought as advertised, but now I feel that a 2.4 really suits the car. It is plenty fast, sounds really sexy, and does not run hot. Nothing compares to the sound of a vintage 911 engine at full song. It brings back old memories of these cars that I used to hear growing up. I had installed an oil cooler set up for the 2.7, so that is there keeping things cool. My engine is an early 2.4T Euro case, built to S specs. Lots of fun! |
seanery |
Oct 31 2018, 03:33 PM
waiting to rebuild whitey! Group: Retired Admin Posts: 15,854 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None |
Does the 2.4T have the noncounterweighted crank like the 2.2T? If so, did you replace your crank? I have a 2.2T that is destined for one of my 914s, rebuilt to a 2.5E or S spec, but damn, cranks are expensive these days!!
BK911 |
Nov 1 2018, 07:51 AM
Senior Member Group: Members Posts: 672 Joined: 19-February 04 From: Rocky Top, TN Member No.: 1,674 Region Association: None |
Does the 2.4T have the noncounterweighted crank like the 2.2T? If so, did you replace your crank? I have a 2.2T that is destined for one of my 914s, rebuilt to a 2.5E or S spec, but damn, cranks are expensive these days!! My engine is an early 2.4T Euro case, built to S specs. Lots of fun! What is a 2.5? A 2.7 bore with a 2.2 stroke? Or a 2.4 with 85mm cylinders? If the former, not sure you want to start with a 2.2T case. |
seanery |
Nov 1 2018, 11:55 PM
I’ve got a 2.2T that is destined to go in the car, but I’ve also got a 7R case and some bits. Ultimately it will be a short stroke with 2.7 sized jugs.
[quote name='BK911' date='Nov 1 2018, 10:51 AM' post='2662016'] [qu[b]ote name='seanery' post='2661851' date='Oct 31 2018, 05:33 PM'] Does the 2.4T have the noncounterweighted crank like the 2.2T? If so, did you replace your crank? I have a 2.2T that is destined for one of my 914s, rebuilt to a 2.5E or S spec, but damn, cranks are expensive these days!! [quote name='Larmo63' post='2661779' date='Oct 31 2018, 12:53 PM'] My engine is an early 2.4T Euro case, built to S specs. Lots of fun! [/quote] [/quote] What is a 2.5? A 2.7 bore with a 2.2 stroke? Or a 2.4 with 85mm cylinders? If the former, not sure you want to start with a 2.2T case. [/quote] |
Lo-Fi Version | Time is now: 2nd June 2024 - 05:55 PM |
