dgale914 |
Newbie ![]() Group: Members Posts: 10 Joined: 5-March 03 Member No.: 395 Region Association: Northern California ![]() |
I've decided to move away from the small block Chevy in my 73 914 and experiment with a 2014 LFX GM V6. My chassis is already set-up for a water cooled motor so a 60degree, 370lb, 340hp all aluminum V6 may be a nice solution in front of a 901 or 915 trans. (old school V8 with aluminum heads is 535lbs and an LS is 434lbs)
All that said, I won't be needing this transmission for the next chapter of my 73 914. -1987 Turbo 930/36 4 Speed Trans -Short Nose Bell Housing -Case SN: 7H01204 ('H' is the year code for 1987) -This trans is 'Flipped' for mid-engine use. (ring and pinion) -Factory Limited Slip -Stock Gearing -Comes with a Cable Shift brand shifter set-up. -Perfect for V8 Conversion or any other High HP/High Torque application. From: 930 Turbo 1986-88 4-speed fully-synchronized transaxle Manufactured by Porsche (ZF) Plate-type limited-slip differential available Gear ratios: 1st gear: 2.25 2nd gear: 1.304 3rd gear: 0.893 4th gear: 0.625 Ring and pinion: 4.22 $6000. Local pick-up is preferred but can also ship if you pay for shipping. I'm in the Sacramento, CA area. |
Gearup |
Member ![]() ![]() Group: Members Posts: 157 Joined: 21-April 15 From: Denver Member No.: 18,660 Region Association: None ![]() |
I've decided to move away from the small block Chevy in my 73 914 and experiment with a 2014 LFX GM V6. My chassis is already set-up for a water cooled motor so a 60degree, 370lb, 340hp all aluminum V6 may be a nice solution in front of a 901 or 915 trans. (old school V8 with aluminum heads is 535lbs and an LS is 434lbs) All that said, I won't be needing this transmission for the next chapter of my 73 914. -1987 Turbo 930/36 4 Speed Trans -Short Nose Bell Housing -Case SN: 7H01204 ('H' is the year code for 1987) -This trans is 'Flipped' for mid-engine use. (ring and pinion) -Factory Limited Slip -Stock Gearing -Comes with a Cable Shift brand shifter set-up. -Perfect for V8 Conversion or any other High HP/High Torque application. From: 930 Turbo 1986-88 4-speed fully-synchronized transaxle Manufactured by Porsche (ZF) Plate-type limited-slip differential available Gear ratios: 1st gear: 2.25 2nd gear: 1.304 3rd gear: 0.893 4th gear: 0.625 Ring and pinion: 4.22 $6000. Local pick-up is preferred but can also ship if you pay for shipping. I'm in the Sacramento, CA area. I have a late model rebuilt 915. Just curious if a trade might be possible. Is your 930 tranny in good shape and do you have the hardware to install it with a Chevy V8. Just throwing this out there as a possibility. Brett |
Lo-Fi Version | Time is now: 16th June 2024 - 02:44 PM |
