I've decided to move away from the small block Chevy in my 73 914 and experiment with a 2014 LFX GM V6. My chassis is already set-up for a water cooled motor so a 60degree, 370lb, 340hp all aluminum V6 may be a nice solution in front of a 901 or 915 trans. (old school V8 with aluminum heads is 535lbs and an LS is 434lbs)
All that said, I won't be needing this transmission for the next chapter of my 73 914.
-1987 Turbo 930/36 4 Speed Trans
-Short Nose Bell Housing
-Case SN: 7H01204 ('H' is the year code for 1987)
-This trans is 'Flipped' for mid-engine use. (ring and pinion)
-Factory Limited Slip
-Stock Gearing
-Comes with a Cable Shift brand shifter set-up.
-Perfect for V8 Conversion or any other High HP/High Torque application.
930 Turbo 1986-88
4-speed fully-synchronized transaxle
Manufactured by Porsche (ZF)
Plate-type limited-slip differential available
Gear ratios:
1st gear: 2.25
2nd gear: 1.304
3rd gear: 0.893
4th gear: 0.625
Ring and pinion: 4.22
$6000. Local pick-up is preferred but can also ship if you pay for shipping. I'm in the Sacramento, CA area.
