> What Motor and Transmission mounts to use, What motor and transmission mounts to use
Ken Mikos
post Oct 28 2018, 07:32 PM
Replacing motor and transmission mounts in a original 1973 1.7. Any suggestion on the type and where to purchase? Thanks,
Ken
Dave_Darling
post Oct 31 2018, 12:05 PM
914 Idiot
For a track-only car? Solid all the way around. Keeps the drivetrain more positively located.
May cause loosening issues with some fasteners on the engine; I seem to recall some kind of issue with Webers being blamed on solid mounts?
--DD
GregAmy
post Nov 1 2018, 07:54 AM
QUOTE(Dave_Darling @ Oct 31 2018, 02:05 PM) *
I'm thinking JWest hard nylon fronts, and Wevo Blues in back?
GregAmy
post Nov 4 2018, 12:04 PM
QUOTE(GregAmy @ Nov 1 2018, 09:54 AM) *
Here's an interesting data point, Dave: my engine is already mounted solid. As in metal-to-metal. In order to fit the dry sump pump in there, Tangerine had fabbed an engine mounting bracket out of steel plate. Pulled the drivetrain this week and noticed it yesterday...that might help to explain how one of the engine frame mount bolts on the outer end of the crossmember had come loose and the nut departed the car...
I'll go with the Wevos in back.
Ken Mikos   What Motor and Transmission mounts to use   Oct 28 2018, 07:32 PM
Dave_Darling   The 73 uses solid outboard mounts between the bar ...   Oct 28 2018, 08:22 PM
914Sixer   Buy stock and be done.   Oct 29 2018, 07:46 AM
UROpartsman   For a '73-'76, engine mount 039 199 231 is...   Oct 29 2018, 10:51 AM
DRPHIL914   For transmission most of us have been using the 91...   Oct 29 2018, 11:00 AM
troth   Very happy with my wevo semi-solid trans mounts. K...   Oct 29 2018, 11:01 AM
DRPHIL914   Very happy with my wevo semi-solid trans mounts. ...   Oct 29 2018, 11:24 AM
troth   Very happy with my wevo semi-solid trans mounts....   Oct 29 2018, 12:08 PM
DRPHIL914   here is a picture of a 911 motor mount used on the...   Oct 29 2018, 11:02 AM
DRPHIL914   stock motor mount   Oct 29 2018, 11:08 AM
Ken Mikos   Thanks for all the follow up. You guys are a great...   Oct 29 2018, 02:52 PM
GregAmy   What's the right combo for a '74 track-onl...   Oct 31 2018, 06:44 AM
pete000   I have been running the Wevo blue Trans mounts fo...   Oct 31 2018, 10:00 AM
Dave_Darling   For a track-only car? Solid all the way around. ...   Oct 31 2018, 12:05 PM
sithot   I seem to recall some kind of issue with Webers ...   Oct 31 2018, 08:14 PM
GregAmy   For a track-only car? Solid all the way around. ...   Nov 1 2018, 07:54 AM
GregAmy   For a track-only car? Solid all the way around....   Nov 4 2018, 12:04 PM
GregAmy   "Solid" as in aluminum-solid? I don...   Oct 31 2018, 12:18 PM
Literati914   *Modified 911 mounts do not have the proper anti...   Oct 31 2018, 06:09 PM
UROpartsman   So, are you saying that either of the engine mount...   Nov 1 2018, 09:53 AM
GeorgeRud   I think either the 914-6, 911, or WEVO mounts will...   Oct 31 2018, 06:39 PM
Literati914   I think either the 914-6, 911, or WEVO mounts wil...   Oct 31 2018, 07:49 PM
mepstein   [quote name='GeorgeRud' post='2661903' date='Oct ...   Oct 31 2018, 07:52 PM
DRPHIL914   [quote name='GeorgeRud' post='2661903' date='Oct ...   Oct 31 2018, 08:03 PM
Larmo63   I'm going to change out my solid aluminum/delr...   Oct 31 2018, 10:27 PM
ConeDodger   I was seduced early on by solid mounts. My car is ...   Nov 1 2018, 08:28 AM
Dave_Darling   My contention is that on a race car, you nut-and-b...   Nov 4 2018, 01:45 PM
GregAmy   Thank you, Dave, I appreciate the advice.   Nov 4 2018, 03:48 PM
Ken Mikos   First drive today after installation of New Motor ...   Mar 17 2019, 07:18 PM
UROpartsman   Excellent Ken, which motor and transmission mounts...   Mar 18 2019, 11:11 AM
Ken Mikos   Excellent Ken, which motor and transmission mount...   Mar 18 2019, 02:39 PM
- Lo-Fi Version Time is now: 4th March 2026 - 11:04 PM
