| betz |
Nov 6 2018, 04:07 PM
Member ![]() ![]() Group: Members Posts: 76 Joined: 22-October 18 From: San Leandro, CA Member No.: 22,593 Region Association: Northern California |
A little background: I have 3 cars besides the 914: A stock '00 Boxster, a restored '86 E30 BMW with a 2.8L stroker M20, and a '06 Outback XT. All manual trans.
I found this 1972 914 1.7 on craigslist for $1600 and the main selling point to me was that most of the parts were there, it just seemed to need some basic TLC to get it running. Also, its a California car and not a total rust bucket. Also hasn't appeared to be in any major accidents. After pretty much finishing my E30 I've been itching for a new project... Ideally smog exempt. (IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-22593-1541542078.1.jpg) The plan for the car is to get it running with the original type 4. The PO, who only had it for a few months, said he thinks it needs a fuel pump... turns out, the fuel pump wasn't even plugged in. So OF COURSE it's not running. He got it to start briefly with just starter fluid, so I'm thinking that's pretty much it. I'm going to bring it back to stock configuration on the D-jet, change out the oil and fuel, plug in the dang fuel pump in and I pretty much expect it to start up no problem. From there, I will get into the restoration phase. Take it down to bare metal (I believe the car was originally black, and has total crap paint job) tackle any rust, then repaint. Then get the interior/ exterior trim all sorted. And, if I get through alll that... I will probably want to undertake a motor swap, unless I'm just in love with the type 4. I tossed a few ideas out there, but my ideal motor would be a light, high revving motor with ITB's. Since S14's are not exactly obtainable, the 20V 4A-GE blacktop is my best idea so far. KEP makes an adapter for it, plus, it doesn't make enough power to break the stock 901 trans. I am a mechanical engineer with access to a machine shop, so fabbing some engine mounts, routing cooling system etc will most likely be pretty doable. What do you guys think? Am I in over my head? |
| theer |
Nov 6 2018, 05:24 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 692 Joined: 31-July 15 From: Dover, MA Member No.: 19,014 Region Association: North East States
What do you guys think? Am I in over my head? (IMG:style_emoticons/default/welcome.png) I had to look up what a 4A-GE blacktop is, but you're definitely not in over your head. 914's have been swapped with many different motors, so an easier route would be to copy what's been done already.. but that's totally up to you. Fix it up and drive it first is a great idea, though. You'll get tired of the T4 soon enough, but will love the handling, etc. Good luck! |
| betz |
Nov 6 2018, 06:19 PM
I had to look up what a 4A-GE blacktop is, but you're definitely not in over your head. 914's have been swapped with many different motors, so an easier route would be to copy what's been done already.. but that's totally up to you. Fix it up and drive it first is a great idea, though. You'll get tired of the T4 soon enough, but will love the handling, etc. Good luck! Thanks for all of the welcomes! I hardly got that on r3vlimited, haha. The 4A-GE is a Yamaha designed Toyota motor made famous by the anime initial D. It's found in the AE86 corolla and the original MR2. The blacktop is the final iteration of the motor, found in some JDM only FWD corollas from the late 90s. It's a 1.6L I4 making 160 hp. Redline is at 8300. 5 valves per cylinder. 11:1 compression. Comes stock with individual throttle bodies and runs off a MAP sensor. This makes fitting it with open air trumpets a bolt on affair. It might just be the best sounding 4 cylinder ever made- in my opinion. I def know it would not be as easy as a subaru or V8 swap. Not the biggest fan of V8s so the subaru motor would probably be the easiest choice for me. Anyways.. hopefully I get it running soon. I'm thinking it could be as soon as this weekend. I haven't actually attempted to start it since I got it, haha. |
betz New 914 owner! Already dreaming of engine swaps... Nov 6 2018, 04:07 PM
aharder :wttc: Nov 6 2018, 04:39 PM
ValcoOscar :wttc: Nov 6 2018, 04:52 PM
mepstein :wttc: Nov 6 2018, 04:58 PM
Shadowfax :wttc:
Looks like a great starting point. Nov 6 2018, 05:46 PM
Chi-town A blacktop is nice but parts are getting harder an... Nov 6 2018, 08:11 PM
betz
A blacktop is nice but parts are getting harder a... Nov 6 2018, 11:24 PM
Tdskip Welcome!
My guess is the height of the engin... Nov 6 2018, 08:22 PM
76-914 :wttc: It will not be difficult to improve upon th... Nov 6 2018, 09:01 PM
Cairo94507 :wttc: Regardless of what you do, have fun doing i... Nov 7 2018, 08:29 AM
Chi-town
A blacktop is nice but parts are getting harder ... Nov 7 2018, 09:03 AM
betz
I did love the sound of the ITBs screaming but y... Nov 7 2018, 11:40 AM
Mueller Welcome to the club!
Quite a few 914 owners d... Nov 7 2018, 10:09 AM
914-300Hemi :wttc: Nov 7 2018, 10:20 AM
914_teener "The plan for the car is to get it running wi... Nov 7 2018, 12:14 PM
MichiganMat Hello from San Jose. I just finished up my WRX sw... Nov 7 2018, 04:47 PM
Chi-town
Not really hurting it too much, seeing as multip... Nov 7 2018, 04:53 PM
betz
A 16v 4AGE with ITB's sounds exactly the sa... Nov 8 2018, 02:17 AM
Andyrew
A 16v 4AGE with ITB's sounds exactly the s... Nov 8 2018, 10:59 AM
Mueller Had I not gotten such a killer deal for my Honda V... Nov 7 2018, 04:59 PM
Andyrew I have a lot of thoughts on this subject :)
Bang... Nov 8 2018, 10:56 AM
mgp4591
Ban... Nov 8 2018, 01:28 PM
Dave_Darling
I thought about the Honda engine and trans swap -... Nov 8 2018, 05:35 PM
Andyrew
I thought about the Honda engine and trans swap ... Nov 8 2018, 05:39 PM
Chris H. Yes the K series is a very strong, cheap, plentifu... Nov 8 2018, 02:13 PM
Rand This subject has been beaten to death. Are you exp... Nov 8 2018, 02:17 PM
betz
This subject has been beaten to death. Are you ex... Nov 8 2018, 04:24 PM
Rand
This subject has been beaten to death. Are you e... Nov 8 2018, 08:15 PM
Andyrew Lots of 914 guys around you... Why dont you go for... Nov 8 2018, 05:12 PM
betz
Lots of 914 guys around you... Why dont you go fo... Nov 8 2018, 06:54 PM
Bleyseng
Lots of 914 guys around you... Why dont you go f... May 15 2019, 07:35 AM
Andyrew DP Nov 8 2018, 05:31 PM
betz Somebody talk me out of buying this guy and pullin... Nov 9 2018, 01:35 PM
Andyrew
Somebody talk me out of buying this guy and pulli... Nov 9 2018, 02:49 PM
betz
You were complaining the subaru being unreliable... Nov 9 2018, 03:32 PM
Andyrew
You were complaining the subaru being unreliabl... Nov 9 2018, 03:57 PM
PatrickB
Somebody talk me out of buying this guy and pulli... Nov 11 2018, 05:52 AM
Chi-town
Somebody talk me out of buying this guy and pulli... Nov 9 2018, 03:40 PM
Andyrew
[quote name='betz' post='2664360' date='Nov 9 201... Nov 9 2018, 03:56 PM
betz
Tell ya what, if you want to waste money like th... Nov 9 2018, 04:11 PM
Larmo63 I read this thread thinking I was logged into 914 ... Nov 9 2018, 04:53 PM
Chi-town
:rotfl: Alfa owners on suicide watch now
Looks ... Nov 9 2018, 05:29 PM
Porschef Buy it for the Brembo calipers
:evilgrin: Nov 9 2018, 05:31 PM
djway https://www.youtube.com/watch?v=tcPgE40t4dc
Well ... Nov 9 2018, 10:50 PM
Chris914n6 More motivation... K20A2 Porsche 911
http://www.9... Nov 10 2018, 01:07 AM
betz
I did my N... Nov 10 2018, 10:13 AM
Dave_Darling
I did my Nissan VQ30DE swap back in 2000 before f... Nov 11 2018, 01:35 PM
Chris914n6
I did my Nissan VQ30DE swap back in 2000 before ... Nov 11 2018, 09:58 PM
Chris914n6 Most of the Subie guys use SpeedHut gauges. Mainly... Nov 10 2018, 12:22 PM
betz I've been sick the past few days, but I couldn... Nov 10 2018, 06:17 PM
Chi-town
I've been sick the past few days, but I could... Nov 11 2018, 01:48 PM
betz I got it started!!!
https://photos.ap... Nov 11 2018, 04:45 PM
Andyrew Awesome! Do a minor tune up and keep driving i... Nov 11 2018, 05:09 PM
Mike Bellis I'm a big advocate of the Audi 20v turbo. I... Nov 11 2018, 08:34 PM
matthepcat Nice to meet you today betz, will be watching the ... Nov 11 2018, 09:05 PM
betz I think my next step is to track down this weird i... Nov 12 2018, 04:00 PM
Dave_Darling First: FUEL LEAKS BAD!!! Make sure y... Nov 12 2018, 04:33 PM
betz
First: FUEL LEAKS BAD!!! Make sure ... Nov 12 2018, 08:15 PM
Andyrew
After driving the 914 I think I might just go a ... Nov 12 2018, 09:38 PM
mepstein My feeling was to do my suby swap with a cheap but... Nov 12 2018, 08:21 PM
Tdskip Going down a path that others have plowed is likel... Nov 13 2018, 07:28 AM
betz
Going down a path that others have plowed is like... Nov 15 2018, 03:43 PM
914_teener
Going down a path that others have plowed is lik... Nov 15 2018, 03:49 PM
betz
Your personnel comments about someone probably ... Nov 15 2018, 04:26 PM
Your personnel comments about someone probably... Nov 15 2018, 04:52 PM
betz
You just described a small to mid six.
I would ... Nov 15 2018, 05:42 PM
Mike Bellis
Going down a path that others have plowed is lik... Nov 27 2018, 07:16 PM
Dave_Darling We know people who run Type IV motors at 7K RPM pr... Nov 15 2018, 06:27 PM
betz Thanks for the reply Dave.
I just made a black fr... Nov 26 2018, 06:34 PM
rhodyguy wow. Nov 26 2018, 07:06 PM
Dave_Darling Well, it sure looks cool! No idea of the answ... Nov 26 2018, 11:18 PM
betz
Well, it sure looks cool! No idea of the ans... Nov 27 2018, 11:17 AM
Larmo63 I'd call Jake Raby and get his opinion.
:st... Nov 27 2018, 12:22 AM
Chris914n6 The 86 is like the 350z... the enthusiasts are doi... Nov 27 2018, 03:15 PM
betz
The 86 is like the 350z... the enthusiasts are do... Nov 27 2018, 03:39 PM
1adam12 I originally thought of doing an FA-20 swap a year... Nov 27 2018, 04:30 PM
betz
I originally thought of doing an FA-20 swap a yea... Nov 27 2018, 05:27 PM
1adam12
I originally thought of doing an FA-20 swap a ye... Nov 27 2018, 06:05 PM
Chi-town FA20 is a joke. Underpowered, unreliable when used... Nov 27 2018, 06:58 PM
betz
FA20 is a joke. Underpowered, unreliable when use... Nov 28 2018, 12:45 AM
Chi-town The EJ series engines even N/A are cheap and easy ... Nov 28 2018, 12:56 AM
betz Welp, after a half a year of deliberation I've... Apr 23 2019, 04:32 PM
rhodyguy What is the timing belt interval for that engine? ... Apr 24 2019, 12:42 PM
Chi-town That's not a mint one, that's your standar... Apr 24 2019, 04:43 PM
betz
That's not a mint one, that's your standa... Apr 24 2019, 05:26 PM
RolinkHaus How about a German engine?? :shades2: :popcorn: Apr 24 2019, 05:50 PM
betz
... Apr 24 2019, 07:13 PM
Grego in Sac
How about a German engine?? :shades2: :popcorn:... Jul 15 2021, 01:30 PM
Chris914n6 You want to do all the usual maintenance items bef... Apr 24 2019, 06:02 PM
2mAn
Thanks for all of the welcomes! I hardly got... May 14 2019, 04:38 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 12:07 PM |
