> How do you remove the crash bars on late doors?
dan10101
post Nov 9 2018, 09:33 PM
TORQUE-o-holic
Yes, I have a cage and I will have door bars.
So I looked and looked, but can't find a write up on how to remove the factory crash bars on late doors? I have 1/2 of it out, but the door latch side is a puzzlement. So far I've cut them in half and was able to cut out the front hinge side.
Can someone help?
Literati914
post Nov 9 2018, 11:15 PM
QUOTE(dan10101 @ Nov 9 2018, 09:33 PM) *
..Yes, I have a cage and I will have door bars.
I'm confused, but whats new!! I mean... you're cutting bars out of these doors to put into your existing doors? As-in "I WILL have door bars if it's the last thing I do!! (IMG:style_emoticons/default/av-943.gif)
.."Or, these are your existing doors and you're cutting the stock bars out (to save weight) because your roll cage has door bars already? Sorry I'm no help. I would have cut the sections out of the each outside end and pulled it out as a whole unit, probably.
EDIT: ok we must have been typing at the same time. I see now, you're saving weight. Good job!
dan10101   How do you remove the crash bars on late doors?   Nov 9 2018, 09:33 PM
914Sixer   I have never seen it done before. I was going to d...   Nov 9 2018, 10:23 PM
dan10101   Well, I'm sure that would work. You would hav...   Nov 9 2018, 11:09 PM
Literati914   ..Yes, I have a cage and I will have door bars. ...   Nov 9 2018, 11:15 PM
dan10101   ..Yes, I have a cage and I will have door bars. ...   Nov 9 2018, 11:47 PM
mepstein   I would have bought early doors.   Nov 9 2018, 11:17 PM
dan10101   I would have bought early doors. hard to do whe...   Nov 9 2018, 11:51 PM
914 Ranch   Just got back from Club NARP where my build thread...   Nov 10 2018, 05:48 AM
dan10101   Just got back from Club NARP where my build threa...   Nov 10 2018, 10:05 AM
914 Ranch   Thanks Joe, I think I'm going the same way ...   Nov 10 2018, 02:39 PM
tazz9924   Just got back from Club NARP where my build thre...   Nov 11 2018, 06:32 AM
dan10101   For lightweight windows remove your window and t...   Nov 11 2018, 09:58 AM
wndsrfr   Anyone have suggestions on where to buy Lexan S...   Nov 11 2018, 03:09 PM
mlindner   Dan, if needed I have a 72/73 early passenger door...   Nov 10 2018, 06:05 AM
wndsrfr   I used a three inch cuter wheel...pretty easy to g...   Nov 10 2018, 07:08 AM
dan10101   I used a three inch cuter wheel...pretty easy to ...   Nov 10 2018, 10:12 AM
Jeff Hail   I used a three inch cuter wheel...pretty easy to ...   Nov 10 2018, 07:29 PM
wndsrfr   I used a three inch cuter wheel...pretty easy to...   Nov 11 2018, 06:31 AM
dan10101   Dan, if needed I have a 72/73 early passenger doo...   Nov 10 2018, 10:07 AM
Mike Bellis   I don't think the weight savings is worth the ...   Nov 10 2018, 11:29 AM
dan10101   I don't think the weight savings is worth the...   Nov 10 2018, 11:48 AM
Mike Bellis   I don't think the weight savings is worth th...   Nov 10 2018, 12:09 PM
dan10101   [quote name='dan10101' post='2664600' date='Nov 1...   Nov 10 2018, 01:36 PM
rgalla9146   [quote name='dan10101' post='2664600' date='Nov ...   Nov 10 2018, 02:13 PM
dan10101   Full cage, empty doors...... full interior......   Nov 10 2018, 09:28 PM
rgalla9146   Full cage, empty doors...... full interior.....   Nov 10 2018, 09:45 PM
dan10101   Now I know why it weighs 2600 lbs......an LS ...   Nov 10 2018, 09:54 PM
rgalla9146   Now I know why it weighs 2600 lbs......an LS...   Nov 10 2018, 10:36 PM
dan10101   Realllly?! You're one step ahead of m...   Nov 10 2018, 10:54 PM
Zippy69   Just as a FYI Rgalla drove it in July 2011 prior t...   Nov 13 2018, 01:04 PM
dan10101   Just as a FYI Rgalla drove it in July 2011 prior ...   Nov 13 2018, 03:18 PM
Zippy69   Just as a FYI Rgalla drove it in July 2011 prior...   Nov 13 2018, 11:28 PM
mlindner   I don't have any numbers to share regarding we...   Nov 10 2018, 01:42 PM
Mike Bellis   Here's some pics in my thread. It's kind o...   Nov 10 2018, 08:18 PM
dan10101   Here's some pics in my thread. It's kind ...   Nov 10 2018, 09:32 PM
dan10101   Here is the latest on the door lightening. I did a...   Nov 10 2018, 09:45 PM
mepstein   There is a company in England that sells a lexan w...   Nov 11 2018, 10:25 AM
sixnotfour   Boom FYI This fiberglass door weighs in at 8 lbs. ...   Nov 11 2018, 12:22 PM
dan10101   Boom FYI This fiberglass door weighs in at 8 lbs....   Nov 11 2018, 02:42 PM
Andyrew   lying bathroom scale. :rotfl:   Nov 12 2018, 09:31 PM
dan10101   lying bathroom scale. :rotfl: HEY! I ...   Nov 13 2018, 12:08 AM
Andyrew   [quote name='Andyrew' post='2665141' date='Nov 12...   Nov 13 2018, 09:50 AM
sixnotfour   https://www.tapplastics.com/   Nov 12 2018, 10:28 AM
dan10101   https://www.tapplastics.com/ Thanks, I might h...   Nov 12 2018, 03:16 PM
- Lo-Fi Version Time is now: 21st July 2026 - 03:50 PM
