| betz |
Nov 6 2018, 04:07 PM
Member ![]() ![]() Group: Members Posts: 76 Joined: 22-October 18 From: San Leandro, CA Member No.: 22,593 Region Association: Northern California |
A little background: I have 3 cars besides the 914: A stock '00 Boxster, a restored '86 E30 BMW with a 2.8L stroker M20, and a '06 Outback XT. All manual trans.
I found this 1972 914 1.7 on craigslist for $1600 and the main selling point to me was that most of the parts were there, it just seemed to need some basic TLC to get it running. Also, its a California car and not a total rust bucket. Also hasn't appeared to be in any major accidents. After pretty much finishing my E30 I've been itching for a new project... Ideally smog exempt. (IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-22593-1541542078.1.jpg) The plan for the car is to get it running with the original type 4. The PO, who only had it for a few months, said he thinks it needs a fuel pump... turns out, the fuel pump wasn't even plugged in. So OF COURSE it's not running. He got it to start briefly with just starter fluid, so I'm thinking that's pretty much it. I'm going to bring it back to stock configuration on the D-jet, change out the oil and fuel, plug in the dang fuel pump in and I pretty much expect it to start up no problem. From there, I will get into the restoration phase. Take it down to bare metal (I believe the car was originally black, and has total crap paint job) tackle any rust, then repaint. Then get the interior/ exterior trim all sorted. And, if I get through alll that... I will probably want to undertake a motor swap, unless I'm just in love with the type 4. I tossed a few ideas out there, but my ideal motor would be a light, high revving motor with ITB's. Since S14's are not exactly obtainable, the 20V 4A-GE blacktop is my best idea so far. KEP makes an adapter for it, plus, it doesn't make enough power to break the stock 901 trans. I am a mechanical engineer with access to a machine shop, so fabbing some engine mounts, routing cooling system etc will most likely be pretty doable. What do you guys think? Am I in over my head? |
| Chris914n6 |
Nov 10 2018, 01:07 AM
Jackstands are my life. ![]() ![]() ![]() ![]() Group: Members Posts: 3,528 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
More motivation... K20A2 Porsche 911
(IMG:http://www.914world.com/bbs2/uploads_offsite/farm5.staticflickr.com-431-1541833657.1.jpg) I did my Nissan VQ30DE swap back in 2000 before forums existed. Fairly easy to do. The most time consuming part was going page by page thru the FSM to find and wire the dozen separate ECU power connections and the gauge wiring. Then after it's running you have to go thru it all again to make it pretty... it's one of the laws of swapping (IMG:style_emoticons/default/av-943.gif) Don't listen to the old folks... 200hp IS the sweet spot. A T4 power build makes sense if you do it yourself, then the bill is under $2k. Otherwise a modern FI motor swap makes more sense. My old timer advice is to attend one of the World events next year and drive a few cars. Then you will have a strong basis to decide on your power level and swap difficulty. |
| betz |
Nov 10 2018, 10:13 AM
More motivation... K20A2 Porsche 911 I did my Nissan VQ30DE swap back in 2000 before forums existed. Fairly easy to do. The most time consuming part was going page by page thru the FSM to find and wire the dozen separate ECU power connections and the gauge wiring. Then after it's running you have to go thru it all again to make it pretty... it's one of the laws of swapping (IMG:style_emoticons/default/av-943.gif) Don't listen to the old folks... 200hp IS the sweet spot. A T4 power build makes sense if you do it yourself, then the bill is under $2k. Otherwise a modern FI motor swap makes more sense. My old timer advice is to attend one of the World events next year and drive a few cars. Then you will have a strong basis to decide on your power level and swap difficulty. Man that K swapped 911.. 11.5 compression with a turbo is BOLD. I'm sure that build costed a fortune. That's actually the part I also figured would be the most time consuming. Which is why a motor with a lot of info floating about and aftermarket would be so useful. I've already looked at some gauges even, ideally I'd like to modify mine to accept the correct signal and go to a higher RPM but that's probably more trouble than it's worth. It's just I like the 914 gauges... Oh well. So, with a T4 build that would cost me $2k.. what kit/ stuff would I be buying? Because I have an engine builder dude I worked with to make my E30 stroker happen. He can do whatever I can't, like a 3 angle valve job, hone the cylinders, etc. I do like the idea of a really hotted up type 4 with dual Webers, also. But obviously would rather have a swap, especially if the cost difference wasn't that much, or the outcome of the T4 was barely over 100hp. In any case I would be doing as much of this as I can on my own. I plan to even sand it down myself however getting someone else to paint it. My friend owns a shop and has a lot of contacts in the auto world, so I can probably get it done for a very reasonable price. The custom work, I plan on designing in solidworks and bringing into my own workplace where they should be able to make it happen. Little parts I can probably get done for free but an engine cradle or something I'd have to pay some hourly rate. And, I definitely plan on driving/ riding in some cars before deciding, definitely. When are the events and are there some in California? |
betz New 914 owner! Already dreaming of engine swaps... Nov 6 2018, 04:07 PM
aharder :wttc: Nov 6 2018, 04:39 PM
ValcoOscar :wttc: Nov 6 2018, 04:52 PM
mepstein :wttc: Nov 6 2018, 04:58 PM
theer
... Nov 6 2018, 05:24 PM
betz
I had to look up what a 4A-GE blacktop is, but y... Nov 6 2018, 06:19 PM
Shadowfax :wttc:
Looks like a great starting point. Nov 6 2018, 05:46 PM
Chi-town A blacktop is nice but parts are getting harder an... Nov 6 2018, 08:11 PM
betz
A blacktop is nice but parts are getting harder a... Nov 6 2018, 11:24 PM
Tdskip Welcome!
My guess is the height of the engin... Nov 6 2018, 08:22 PM
76-914 :wttc: It will not be difficult to improve upon th... Nov 6 2018, 09:01 PM
Cairo94507 :wttc: Regardless of what you do, have fun doing i... Nov 7 2018, 08:29 AM
Chi-town
A blacktop is nice but parts are getting harder ... Nov 7 2018, 09:03 AM
betz
I did love the sound of the ITBs screaming but y... Nov 7 2018, 11:40 AM
Mueller Welcome to the club!
Quite a few 914 owners d... Nov 7 2018, 10:09 AM
914-300Hemi :wttc: Nov 7 2018, 10:20 AM
914_teener "The plan for the car is to get it running wi... Nov 7 2018, 12:14 PM
MichiganMat Hello from San Jose. I just finished up my WRX sw... Nov 7 2018, 04:47 PM
Chi-town
Not really hurting it too much, seeing as multip... Nov 7 2018, 04:53 PM
betz
A 16v 4AGE with ITB's sounds exactly the sa... Nov 8 2018, 02:17 AM
Andyrew
A 16v 4AGE with ITB's sounds exactly the s... Nov 8 2018, 10:59 AM
Mueller Had I not gotten such a killer deal for my Honda V... Nov 7 2018, 04:59 PM
Andyrew I have a lot of thoughts on this subject :)
Bang... Nov 8 2018, 10:56 AM
mgp4591
Ban... Nov 8 2018, 01:28 PM
Dave_Darling
I thought about the Honda engine and trans swap -... Nov 8 2018, 05:35 PM
Andyrew
I thought about the Honda engine and trans swap ... Nov 8 2018, 05:39 PM
Chris H. Yes the K series is a very strong, cheap, plentifu... Nov 8 2018, 02:13 PM
Rand This subject has been beaten to death. Are you exp... Nov 8 2018, 02:17 PM
betz
This subject has been beaten to death. Are you ex... Nov 8 2018, 04:24 PM
Rand
This subject has been beaten to death. Are you e... Nov 8 2018, 08:15 PM
Andyrew Lots of 914 guys around you... Why dont you go for... Nov 8 2018, 05:12 PM
betz
Lots of 914 guys around you... Why dont you go fo... Nov 8 2018, 06:54 PM
Bleyseng
Lots of 914 guys around you... Why dont you go f... May 15 2019, 07:35 AM
Andyrew DP Nov 8 2018, 05:31 PM
betz Somebody talk me out of buying this guy and pullin... Nov 9 2018, 01:35 PM
Andyrew
Somebody talk me out of buying this guy and pulli... Nov 9 2018, 02:49 PM
betz
You were complaining the subaru being unreliable... Nov 9 2018, 03:32 PM
Andyrew
You were complaining the subaru being unreliabl... Nov 9 2018, 03:57 PM
PatrickB
Somebody talk me out of buying this guy and pulli... Nov 11 2018, 05:52 AM
Chi-town
Somebody talk me out of buying this guy and pulli... Nov 9 2018, 03:40 PM
Andyrew
[quote name='betz' post='2664360' date='Nov 9 201... Nov 9 2018, 03:56 PM
betz
Tell ya what, if you want to waste money like th... Nov 9 2018, 04:11 PM
Larmo63 I read this thread thinking I was logged into 914 ... Nov 9 2018, 04:53 PM
Chi-town
:rotfl: Alfa owners on suicide watch now
Looks ... Nov 9 2018, 05:29 PM
Porschef Buy it for the Brembo calipers
:evilgrin: Nov 9 2018, 05:31 PM
djway https://www.youtube.com/watch?v=tcPgE40t4dc
Well ... Nov 9 2018, 10:50 PM
Dave_Darling
I did my Nissan VQ30DE swap back in 2000 before f... Nov 11 2018, 01:35 PM
Chris914n6
I did my Nissan VQ30DE swap back in 2000 before ... Nov 11 2018, 09:58 PM
Chris914n6 Most of the Subie guys use SpeedHut gauges. Mainly... Nov 10 2018, 12:22 PM
betz I've been sick the past few days, but I couldn... Nov 10 2018, 06:17 PM
Chi-town
I've been sick the past few days, but I could... Nov 11 2018, 01:48 PM
betz I got it started!!!
https://photos.ap... Nov 11 2018, 04:45 PM
Andyrew Awesome! Do a minor tune up and keep driving i... Nov 11 2018, 05:09 PM
Mike Bellis I'm a big advocate of the Audi 20v turbo. I... Nov 11 2018, 08:34 PM
matthepcat Nice to meet you today betz, will be watching the ... Nov 11 2018, 09:05 PM
betz I think my next step is to track down this weird i... Nov 12 2018, 04:00 PM
Dave_Darling First: FUEL LEAKS BAD!!! Make sure y... Nov 12 2018, 04:33 PM
betz
First: FUEL LEAKS BAD!!! Make sure ... Nov 12 2018, 08:15 PM
Andyrew
After driving the 914 I think I might just go a ... Nov 12 2018, 09:38 PM
mepstein My feeling was to do my suby swap with a cheap but... Nov 12 2018, 08:21 PM
Tdskip Going down a path that others have plowed is likel... Nov 13 2018, 07:28 AM
betz
Going down a path that others have plowed is like... Nov 15 2018, 03:43 PM
914_teener
Going down a path that others have plowed is lik... Nov 15 2018, 03:49 PM
betz
Your personnel comments about someone probably ... Nov 15 2018, 04:26 PM
Your personnel comments about someone probably... Nov 15 2018, 04:52 PM
betz
You just described a small to mid six.
I would ... Nov 15 2018, 05:42 PM
Mike Bellis
Going down a path that others have plowed is lik... Nov 27 2018, 07:16 PM
Dave_Darling We know people who run Type IV motors at 7K RPM pr... Nov 15 2018, 06:27 PM
betz Thanks for the reply Dave.
I just made a black fr... Nov 26 2018, 06:34 PM
rhodyguy wow. Nov 26 2018, 07:06 PM
Dave_Darling Well, it sure looks cool! No idea of the answ... Nov 26 2018, 11:18 PM
betz
Well, it sure looks cool! No idea of the ans... Nov 27 2018, 11:17 AM
Larmo63 I'd call Jake Raby and get his opinion.
:st... Nov 27 2018, 12:22 AM
Chris914n6 The 86 is like the 350z... the enthusiasts are doi... Nov 27 2018, 03:15 PM
betz
The 86 is like the 350z... the enthusiasts are do... Nov 27 2018, 03:39 PM
1adam12 I originally thought of doing an FA-20 swap a year... Nov 27 2018, 04:30 PM
betz
I originally thought of doing an FA-20 swap a yea... Nov 27 2018, 05:27 PM
1adam12
I originally thought of doing an FA-20 swap a ye... Nov 27 2018, 06:05 PM
Chi-town FA20 is a joke. Underpowered, unreliable when used... Nov 27 2018, 06:58 PM
betz
FA20 is a joke. Underpowered, unreliable when use... Nov 28 2018, 12:45 AM
Chi-town The EJ series engines even N/A are cheap and easy ... Nov 28 2018, 12:56 AM
betz Welp, after a half a year of deliberation I've... Apr 23 2019, 04:32 PM
rhodyguy What is the timing belt interval for that engine? ... Apr 24 2019, 12:42 PM
Chi-town That's not a mint one, that's your standar... Apr 24 2019, 04:43 PM
betz
That's not a mint one, that's your standa... Apr 24 2019, 05:26 PM
RolinkHaus How about a German engine?? :shades2: :popcorn: Apr 24 2019, 05:50 PM
betz
... Apr 24 2019, 07:13 PM
Grego in Sac
How about a German engine?? :shades2: :popcorn:... Jul 15 2021, 01:30 PM
Chris914n6 You want to do all the usual maintenance items bef... Apr 24 2019, 06:02 PM
2mAn
Thanks for all of the welcomes! I hardly got... May 14 2019, 04:38 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 12:08 PM |
