Carb issue's |
Carb issue's |
mb911 |
Nov 9 2018, 09:00 PM
914 Guru Group: Members Posts: 6,886 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
I have some clean (so I think) Weber 40s for my engine.. Trying to get the engine running. I can get it to fire and run 5-10 seconds and it dies out.. This is not off of the idle Circuit.. I have little experience with webers and some experience with zenith 40 tins.. Mostly efi on my 911s and 914s.. I put new gaskets and correct new jets in everything.. What would be your suggestions as first thing to look at? Accelerator pump squirters on 456 bank don't work as the bowls empty and don't refill ..
Love to borrow a set of carbs to set timing and refigure out the carbs but not sure if that is possible. Any Weber carb experts?? The new ones are looking pretty enticing... |
Retroracer |
Nov 10 2018, 07:08 PM
Senior Member Group: Members Posts: 616 Joined: 7-July 13 From: Bend OR Member No.: 16,100 Region Association: Pacific Northwest |
The float level indicator tool is a good place to start.
I notice on your bench test jig you have an electric fuel pump but no obvious pressure regulator. Have you measured the fuel pressure as presented to the carbs? The Webers (and Zeniths for that matter) are expecting 3-5 PSI there - higher pressures can overcome float needles and flood the chambers. - Tony |
mb911 |
Nov 10 2018, 07:45 PM
The float level indicator tool is a good place to start. I notice on your bench test jig you have an electric fuel pump but no obvious pressure regulator. Have you measured the fuel pressure as presented to the carbs? The Webers (and Zeniths for that matter) are expecting 3-5 PSI there - higher pressures can overcome float needles and flood the chambers. - Tony Tony I am not running one as of yet. This pump only provides 3.5 psi so thought I was good to go.. I will probably add a regulator as well better safe then sorry.. |
Lo-Fi Version | Time is now: 12th June 2024 - 02:01 AM |
