> How do you remove the crash bars on late doors?
dan10101
post Nov 9 2018, 09:33 PM
TORQUE-o-holic
Yes, I have a cage and I will have door bars.
So I looked and looked, but can't find a write up on how to remove the factory crash bars on late doors? I have 1/2 of it out, but the door latch side is a puzzlement. So far I've cut them in half and was able to cut out the front hinge side.
Can someone help?
Mike Bellis
post Nov 10 2018, 08:18 PM
Resident Electrician
Here's some pics in my thread. It's kind of hard to see all the details where it mounts right above the front suspension mounts and ties into the tow bar tabs. The bars are welded to 1/4 plate, that is welded and gusseted to square tubing that ties above the suspension mounts.
http://www.914world.com/bbs2/index.php?sho...7914&st=420
EDIT: front bar is 1" 0.120 wall DOM tubing. Rest of the cage is 1-5/8" tubing.
dan10101   How do you remove the crash bars on late doors?   Nov 9 2018, 09:33 PM
914Sixer   I have never seen it done before. I was going to d...   Nov 9 2018, 10:23 PM
dan10101   Well, I'm sure that would work. You would hav...   Nov 9 2018, 11:09 PM
Literati914   ..Yes, I have a cage and I will have door bars. ...   Nov 9 2018, 11:15 PM
dan10101   ..Yes, I have a cage and I will have door bars. ...   Nov 9 2018, 11:47 PM
mepstein   I would have bought early doors.   Nov 9 2018, 11:17 PM
dan10101   I would have bought early doors. hard to do whe...   Nov 9 2018, 11:51 PM
914 Ranch   Just got back from Club NARP where my build thread...   Nov 10 2018, 05:48 AM
dan10101   Just got back from Club NARP where my build threa...   Nov 10 2018, 10:05 AM
914 Ranch   Thanks Joe, I think I'm going the same way ...   Nov 10 2018, 02:39 PM
tazz9924   Just got back from Club NARP where my build thre...   Nov 11 2018, 06:32 AM
dan10101   For lightweight windows remove your window and t...   Nov 11 2018, 09:58 AM
wndsrfr   Anyone have suggestions on where to buy Lexan S...   Nov 11 2018, 03:09 PM
mlindner   Dan, if needed I have a 72/73 early passenger door...   Nov 10 2018, 06:05 AM
wndsrfr   I used a three inch cuter wheel...pretty easy to g...   Nov 10 2018, 07:08 AM
dan10101   I used a three inch cuter wheel...pretty easy to ...   Nov 10 2018, 10:12 AM
Jeff Hail   I used a three inch cuter wheel...pretty easy to ...   Nov 10 2018, 07:29 PM
wndsrfr   I used a three inch cuter wheel...pretty easy to...   Nov 11 2018, 06:31 AM
dan10101   Dan, if needed I have a 72/73 early passenger doo...   Nov 10 2018, 10:07 AM
Mike Bellis   I don't think the weight savings is worth the ...   Nov 10 2018, 11:29 AM
dan10101   I don't think the weight savings is worth the...   Nov 10 2018, 11:48 AM
Mike Bellis   I don't think the weight savings is worth th...   Nov 10 2018, 12:09 PM
dan10101   [quote name='dan10101' post='2664600' date='Nov 1...   Nov 10 2018, 01:36 PM
rgalla9146   [quote name='dan10101' post='2664600' date='Nov ...   Nov 10 2018, 02:13 PM
dan10101   Full cage, empty doors...... full interior......   Nov 10 2018, 09:28 PM
rgalla9146   Full cage, empty doors...... full interior.....   Nov 10 2018, 09:45 PM
dan10101   Now I know why it weighs 2600 lbs......an LS ...   Nov 10 2018, 09:54 PM
rgalla9146   Now I know why it weighs 2600 lbs......an LS...   Nov 10 2018, 10:36 PM
dan10101   Realllly?! You're one step ahead of m...   Nov 10 2018, 10:54 PM
Zippy69   Just as a FYI Rgalla drove it in July 2011 prior t...   Nov 13 2018, 01:04 PM
dan10101   Just as a FYI Rgalla drove it in July 2011 prior ...   Nov 13 2018, 03:18 PM
Zippy69   Just as a FYI Rgalla drove it in July 2011 prior...   Nov 13 2018, 11:28 PM
mlindner   I don't have any numbers to share regarding we...   Nov 10 2018, 01:42 PM
Mike Bellis   Here's some pics in my thread. It's kind o...   Nov 10 2018, 08:18 PM
dan10101   Here's some pics in my thread. It's kind ...   Nov 10 2018, 09:32 PM
dan10101   Here is the latest on the door lightening. I did a...   Nov 10 2018, 09:45 PM
mepstein   There is a company in England that sells a lexan w...   Nov 11 2018, 10:25 AM
sixnotfour   Boom FYI This fiberglass door weighs in at 8 lbs. ...   Nov 11 2018, 12:22 PM
dan10101   Boom FYI This fiberglass door weighs in at 8 lbs....   Nov 11 2018, 02:42 PM
Andyrew   lying bathroom scale. :rotfl:   Nov 12 2018, 09:31 PM
dan10101   lying bathroom scale. :rotfl: HEY! I ...   Nov 13 2018, 12:08 AM
Andyrew   [quote name='Andyrew' post='2665141' date='Nov 12...   Nov 13 2018, 09:50 AM
sixnotfour   https://www.tapplastics.com/   Nov 12 2018, 10:28 AM
dan10101   https://www.tapplastics.com/ Thanks, I might h...   Nov 12 2018, 03:16 PM
- Lo-Fi Version Time is now: 21st July 2026 - 03:49 PM
