> How do you remove the crash bars on late doors?
dan10101
post Nov 9 2018, 09:33 PM
TORQUE-o-holic
Yes, I have a cage and I will have door bars.
So I looked and looked, but can't find a write up on how to remove the factory crash bars on late doors? I have 1/2 of it out, but the door latch side is a puzzlement. So far I've cut them in half and was able to cut out the front hinge side.
Can someone help?
Mike Bellis
post Nov 10 2018, 11:29 AM
Resident Electrician
I don't think the weight savings is worth the safety trade off. Especially since with your HP & torque, you will never feel the difference.
dan10101
post Nov 10 2018, 11:48 AM
TORQUE-o-holic
QUOTE(Mike Bellis @ Nov 10 2018, 09:29 AM) *
Probably not, but I can't get out of my head how much a porker it is. Almost 2600# before I started with it. heck, my 944 was 2900.
What does yours weigh?
Joe Sharp, I can't get over your's being 1000# lighter.... I'm enjoying reading your thread.. Thanks.
Mike Bellis
post Nov 10 2018, 12:09 PM
QUOTE(dan10101 @ Nov 10 2018, 10:48 AM) *
I'm just under 2300 lbs. Not sure where you extra 300 came from. Although I could be a little heavier since I added caging up front and tied in my tow bar connections. Still your going to be close to 500ft lbs pushing that thing. You won't feel the added couple pounds.
dan10101
post Nov 10 2018, 01:36 PM
TORQUE-o-holic
QUOTE(Mike Bellis @ Nov 10 2018, 10:09 AM) *
Joe Sharp, I can't get over yours being 1000# lighter.... I'm enjoying reading your thread.. Thanks.
I'm not sure that everything fiberglass is saving any weight. It's nice solid fiberglass, thick stuff, not the flimsy stuff I've seen. That said, except for doors, A pillars and sail panels, everything exposed is fiberglass. Oh, and the engine lid is stock. But the cage is very well constructed. Full interior with 4 speaker stereo. Plus a few added pieces that probably are heavier than they need to be.
I'm curious about how your added bars up front. That's one area I will likely be adding tubing.
Back to cutting on the door. (IMG:style_emoticons/default/sawzall-smiley.gif)
rgalla9146
post Nov 10 2018, 02:13 PM
QUOTE(dan10101 @ Nov 10 2018, 02:36 PM) *
Full cage, empty doors...... full interior....four speaker stereo ? 2600 lbs. ! Very confusing. What is it ?
dan10101
post Nov 10 2018, 09:28 PM
TORQUE-o-holic
QUOTE(rgalla9146 @ Nov 10 2018, 12:13 PM) *
Actually, I was saying that everything was fiberglass except the doors and the other things mentioned.
but Now they will be empty! Mostly...
In my Signature is the (re-)build thread.
But it's this car on it's way to a new life after a unfortunate meeting with some pine trees.
looked like this when I got it.
check my thread for the latest update.
I started this thread because I had a need for additional info on doors.
rgalla9146
post Nov 10 2018, 09:45 PM
QUOTE(dan10101 @ Nov 10 2018, 10:28 PM) *
Now I know why it weighs 2600 lbs......an LS engine.
I drove the car when Paul owned it.
I didn't notice the four speaker stereo.
I'll bet the pine trees ran out onto the road.
dan10101
post Nov 10 2018, 09:54 PM
TORQUE-o-holic
QUOTE(rgalla9146 @ Nov 10 2018, 07:45 PM) *
Realllly?!
You're one step ahead of me. I've only driven it up and down the driveway. (and left some marks.)
So tell me your impression of the car overall and I'm curious of your thoughts on the engine tapping. It seems to have been there even when Bill first built it according to youtube videos.
Yeah the speakers are top notch, not the lightweight cheapies. I'll likely replace them with easily removable pods that will go behind the drivers head. between the stereo and the door work, I just saved 100#. Yay Me!
rgalla9146
post Nov 10 2018, 10:36 PM
QUOTE(dan10101 @ Nov 10 2018, 10:54 PM) *
Realllly?!
I don't know much about the engine. It is not stock. It had been disassembled and
some incompatible or non-streetable parts were changed.
Tapping ? don't know.
The clutch was heavy and difficult to modulate. The pan around the pedal cluster
was flexing. A fabricated reinforcement bracket was a 'bandaid'
The gearshift linkage barely worked. My efforts were experimental with existing
equipment. Little if any improvement. Limited time and budget.
The car then went to a well known east coast shop.
Big opportunity for development.
dan10101
post Nov 10 2018, 10:54 PM
TORQUE-o-holic
QUOTE(rgalla9146 @ Nov 10 2018, 08:36 PM) *
Realllly?!
Thanks for your insights. I really appreciate it.
A couple of those items were worked on when Paul owned it. I don't know if they were done before or after you drove it. the clutch was changed to a lighter one. A smaller cam was installed but it's still over 500 crank hp. The gearshift brackets were improved. But I agree that there is room for improvement in the shifting. Seems stiff to me. The engine is still a bit noisy, but it could be forged pistons/rod/crank in an aluminum block with headers and aluminum heads. or so the "Internet" says...
dan10101   How do you remove the crash bars on late doors?   Nov 9 2018, 09:33 PM
914Sixer   I have never seen it done before. I was going to d...   Nov 9 2018, 10:23 PM
dan10101   Well, I'm sure that would work. You would hav...   Nov 9 2018, 11:09 PM
Literati914   ..Yes, I have a cage and I will have door bars. ...   Nov 9 2018, 11:15 PM
dan10101   ..Yes, I have a cage and I will have door bars. ...   Nov 9 2018, 11:47 PM
mepstein   I would have bought early doors.   Nov 9 2018, 11:17 PM
dan10101   I would have bought early doors. hard to do whe...   Nov 9 2018, 11:51 PM
914 Ranch   Just got back from Club NARP where my build thread...   Nov 10 2018, 05:48 AM
dan10101   Just got back from Club NARP where my build threa...   Nov 10 2018, 10:05 AM
914 Ranch   Thanks Joe, I think I'm going the same way ...   Nov 10 2018, 02:39 PM
tazz9924   Just got back from Club NARP where my build thre...   Nov 11 2018, 06:32 AM
dan10101   For lightweight windows remove your window and t...   Nov 11 2018, 09:58 AM
wndsrfr   Anyone have suggestions on where to buy Lexan S...   Nov 11 2018, 03:09 PM
mlindner   Dan, if needed I have a 72/73 early passenger door...   Nov 10 2018, 06:05 AM
wndsrfr   I used a three inch cuter wheel...pretty easy to g...   Nov 10 2018, 07:08 AM
dan10101   I used a three inch cuter wheel...pretty easy to ...   Nov 10 2018, 10:12 AM
Jeff Hail   I used a three inch cuter wheel...pretty easy to ...   Nov 10 2018, 07:29 PM
wndsrfr   I used a three inch cuter wheel...pretty easy to...   Nov 11 2018, 06:31 AM
dan10101   Dan, if needed I have a 72/73 early passenger doo...   Nov 10 2018, 10:07 AM
Mike Bellis   I don't think the weight savings is worth the ...   Nov 10 2018, 11:29 AM
dan10101   I don't think the weight savings is worth the...   Nov 10 2018, 11:48 AM
Mike Bellis   I don't think the weight savings is worth th...   Nov 10 2018, 12:09 PM
dan10101   [quote name='dan10101' post='2664600' date='Nov 1...   Nov 10 2018, 01:36 PM
rgalla9146   [quote name='dan10101' post='2664600' date='Nov ...   Nov 10 2018, 02:13 PM
dan10101   Full cage, empty doors...... full interior......   Nov 10 2018, 09:28 PM
rgalla9146   Full cage, empty doors...... full interior.....   Nov 10 2018, 09:45 PM
dan10101   Now I know why it weighs 2600 lbs......an LS ...   Nov 10 2018, 09:54 PM
rgalla9146   Now I know why it weighs 2600 lbs......an LS...   Nov 10 2018, 10:36 PM
dan10101   Realllly?! You're one step ahead of m...   Nov 10 2018, 10:54 PM
Zippy69   Just as a FYI Rgalla drove it in July 2011 prior t...   Nov 13 2018, 01:04 PM
dan10101   Just as a FYI Rgalla drove it in July 2011 prior ...   Nov 13 2018, 03:18 PM
Zippy69   Just as a FYI Rgalla drove it in July 2011 prior...   Nov 13 2018, 11:28 PM
mlindner   I don't have any numbers to share regarding we...   Nov 10 2018, 01:42 PM
Mike Bellis   Here's some pics in my thread. It's kind o...   Nov 10 2018, 08:18 PM
dan10101   Here's some pics in my thread. It's kind ...   Nov 10 2018, 09:32 PM
dan10101   Here is the latest on the door lightening. I did a...   Nov 10 2018, 09:45 PM
mepstein   There is a company in England that sells a lexan w...   Nov 11 2018, 10:25 AM
sixnotfour   Boom FYI This fiberglass door weighs in at 8 lbs. ...   Nov 11 2018, 12:22 PM
dan10101   Boom FYI This fiberglass door weighs in at 8 lbs....   Nov 11 2018, 02:42 PM
Andyrew   lying bathroom scale. :rotfl:   Nov 12 2018, 09:31 PM
dan10101   lying bathroom scale. :rotfl: HEY! I ...   Nov 13 2018, 12:08 AM
Andyrew   [quote name='Andyrew' post='2665141' date='Nov 12...   Nov 13 2018, 09:50 AM
sixnotfour   https://www.tapplastics.com/   Nov 12 2018, 10:28 AM
dan10101   https://www.tapplastics.com/ Thanks, I might h...   Nov 12 2018, 03:16 PM
- Lo-Fi Version Time is now: 21st July 2026 - 03:48 PM
