Alternative Air Conditioning? |
euro911 |
Nov 22 2018, 11:48 PM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,851 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
Saw this on line, wondering if one of these could mounted in the front trunk and ducted into the fresh air system's vents?
Looks like it only draws about 7.5 amps at 13.5 volts (and I'm going to be installing one of Peter Newman's 160 amp alternators in the '71 914) (IMG:style_emoticons/default/idea.gif) https://www.banggood.com/12V-24V-Small-Car-...ur_warehouse=CN |
Valy |
Nov 23 2018, 02:58 AM
Senior Member Group: Members Posts: 1,677 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
This is just the evaporator. You will also need to install the compressor somewhere and route the pipes to this unit. See the pipes outlets at the bottom.
euro911 |
Nov 23 2018, 05:31 AM
This is just the evaporator. You will also need to install the compressor somewhere and route the pipes to this unit. See the pipes outlets at the bottom. That question was asked on the web page:Q : Is this a standalone air conditioner? or does it need a separate compressor? A : Hi, it is a standalone air conditioner. Answered by Elaine on November 01,2018 It's supposedly just a mini self contained unit, similar to a window air conditioner for your home. The nipples might be the high & low side ports of the system, for adding freon. |
Lo-Fi Version | Time is now: 2nd June 2024 - 01:44 PM |
