Throttle body - am I missing parts? |
rjames |
Nov 28 2018, 11:52 PM
I'm made of metal Group: Members Posts: 3,960 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
I am chasing down a vacuum leak.
I replaced a worn late throttle body with a NOS early throttle body. A throttle body rebuild post I came across shows a brass ring seal and a seal that goes around the shaft on the end where it enters o the throttle body. Neither of the TBs I have have the brass ring or the seal. Are there supposed to be a ring & seal on each side of the TB? Are these available? Are they necessary? Are they the cause of my vacuum leak? I can't detect any play in the shaft. Picture I found that shows the brass ring Pic of a post I found that shows all the parts: |
bretth |
Nov 29 2018, 10:38 AM
Senior Member Group: Members Posts: 899 Joined: 23-June 15 From: Central TX Member No.: 18,882 Region Association: Southwest Region |
I believe the brass bushing is an aftermarket upgrade. The shaft runs bare on the aluminum housing which will wear out over time. There is a seal on the 1.8 that goes here, not sure if they all had it.
Lo-Fi Version | Time is now: 11th June 2024 - 05:53 PM |
