> Clutch Tube Broke, and I'm glad of it
76-914
post Nov 28 2018, 09:59 PM
Never thought I'd say this but I'm glad it happened. I'd been adjusting the cable tension on the V8 914 thinking the new cable was kaput but I felt it in the pedal today for the first time. It's a piece of cake repair compared to some other things I've been wrestling with. Wish @cuddy_k was still in this neck of the woods; I'd video the repair. (IMG:style_emoticons/default/sad.gif)
iankarr
post Nov 29 2018, 02:13 PM
When it happened on mine, the pedal felt "springy", like it was "bowing" rather than pulling.
post Nov 29 2018, 04:13 PM
QUOTE(cuddy_k @ Nov 29 2018, 12:13 PM) *
Was your break at the rear of the tunnel. I haven't had one tear loose at the rear yet. I've seen it on others though. (IMG:style_emoticons/default/beerchug.gif)
iankarr
post Nov 29 2018, 10:52 PM
QUOTE(76-914 @ Nov 29 2018, 05:13 PM) *
On my 73 it broke at the rear. On the 74, it was the front. Both felt kinda the same.
post Nov 30 2018, 07:09 PM
QUOTE(cuddy_k @ Nov 29 2018, 08:52 PM) *
IIRC, there are 3. The front 2 a fairly close to one another. The rear one breaks easily in "the rust buckets" as the lower firewall gets the rust worm. If it looks like the rust worm ate the tube away once I get in there I will convert to hydraulic and just use it as the sleeve for the AN-3 line. (IMG:style_emoticons/default/beerchug.gif)
76-914   Clutch Tube Broke   Nov 28 2018, 09:59 PM
jim_hoyland   Good to hear you got it fixed; what did you do ? R...   Nov 28 2018, 10:07 PM
76-914   Haven't done it on this car yet. It will have ...   Nov 29 2018, 01:24 PM
cuddy_k   Never thought I'd say this but I'm glad i...   Nov 29 2018, 01:27 PM
MikeM   What did you feel in the pedal? Mike   Nov 29 2018, 01:56 PM
76-914   What did you feel in the pedal? Mike I felt the ...   Nov 29 2018, 04:08 PM
cuddy_k   When it happened on mine, the pedal felt "spr...   Nov 29 2018, 02:13 PM
76-914   When it happened on mine, the pedal felt "sp...   Nov 29 2018, 04:13 PM
cuddy_k   When it happened on mine, the pedal felt "s...   Nov 29 2018, 10:52 PM
76-914   [quote name='76-914' post='2669738' date='No...   Nov 30 2018, 07:09 PM
MikeM   Springy as in very "light"? Pretty sure ...   Nov 29 2018, 02:15 PM
cuddy_k   Springy as in very "light"? Pretty sure...   Nov 29 2018, 02:32 PM
dwillouby   Time to switch to a Hyd clutch. :) David   Nov 29 2018, 03:03 PM
76-914   Time to switch to a Hyd clutch. :) David That...   Nov 29 2018, 04:11 PM
RickS   The retaining clips broke in mine in two or maybe ...   Nov 29 2018, 09:59 PM
GaroldShaffer   When my clutch tube broke I wasn't able to hit...   Nov 29 2018, 10:19 PM
MikeM   Thanks guys. This is all good info!! I hav...   Nov 30 2018, 10:21 AM
JeffBowlsby   :D   Dec 1 2018, 12:23 PM
76-914   Great pic Jeff. I just got it back together. I was...   Dec 1 2018, 06:24 PM
- Lo-Fi Version Time is now: 1st September 2025 - 09:38 AM
