> Spot welder access?, what are these holes for and can I weld them up?
amfab
post Dec 1 2018, 05:06 PM
I always assumed the big holes—the 3 or 4 inch diameter ones like in the floor pan and the rear trunk floor that have the twist-in caps—were for spot welder access during manufacturing.
I see there are some other smaller detents—maybe 1-3/4in diameter with half moon cut outs creating a sort of flap near the pedal cluster for example. Were these for the same purpose? Maybe they had an odd spot weld to get to, so they bent them open, did the weld, then bent them back and seam sealed them closed?
If this is the case, is there any reason—other than authenticity—to not weld them closed while I am cleaning up the body before blasting and priming?
Thanks In advance
-Andrew
bbrock
post Dec 1 2018, 06:27 PM
I thought maybe the c-shaped slots were for drainage when the chassis was dipped but really have no clue. They had little metal discs glued over them with seam sealer. When I replaced my floor, I went to great pains to re-cut the openings for the twist on spot weld plugs, but I didn't re-cut those slots. I did replace the metal discs in the divots only because I'm a freak. I don't think it matters if you weld or seal as long as they are closed up.
- Lo-Fi Version Time is now: 19th July 2025 - 04:57 PM
