amfab |
Member ![]() ![]() Group: Members Posts: 401 Joined: 17-May 16 From: Los Angeles Member No.: 20,004 Region Association: None ![]() ![]() |
I always assumed the big holes—the 3 or 4 inch diameter ones like in the floor pan and the rear trunk floor that have the twist-in caps—were for spot welder access during manufacturing.
I see there are some other smaller detents—maybe 1-3/4in diameter with half moon cut outs creating a sort of flap near the pedal cluster for example. Were these for the same purpose? Maybe they had an odd spot weld to get to, so they bent them open, did the weld, then bent them back and seam sealed them closed? If this is the case, is there any reason—other than authenticity—to not weld them closed while I am cleaning up the body before blasting and priming? Thanks In advance -Andrew |
second wind |
Senior Member ![]() ![]() ![]() Group: Members Posts: 862 Joined: 30-December 10 From: Los Angeles, California Member No.: 12,543 Region Association: Southern California ![]() ![]() |
Dipped for what?
gg |
jtprettyman |
Rust Bucket Owner ![]() ![]() Group: Members Posts: 109 Joined: 5-May 15 From: Murfreesboro Tennessee Member No.: 18,707 Region Association: South East States ![]() ![]() |
Lo-Fi Version | Time is now: 19th July 2025 - 04:42 PM |
