| naro914 |
Oct 26 2018, 08:33 AM
Losing my mind... ![]() ![]() ![]() ![]() Group: Members Posts: 2,476 Joined: 26-May 06 From: Charlotte, NC Member No.: 6,073 Region Association: South East States |
with all the work we're doing on Papa Smurf, one of big pieces of the development is tying the roll cage to the rear and front suspension points, plus doing tubing to strengthen other points around the car.
Would like to see how people run the tubes from the roll cage, through the fire wall or window, through the engine compartment area, into the rear trunk to the shock towers. We have things in the way there, but will move around if needed.... Thanks! |
| GregAmy |
Dec 11 2018, 08:56 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,651 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States
Good morning! Just catching this thread, wanted to follow up. I am a Nationally-licensed SCCA scrutineer and a racer.
First, what the regs were when the car was built*, or what someone may have approved in the past, is not relevant. You have to meet current GCR regs to run in SCCA Club Racing. The GCR is constantly updated and can be found here: https://www.scca.com/pages/cars-and-rules Rollcage regs have been fairly consistent over the last decade or so; major changes in recent years include: - Requirement for full-width main hoop bar (mid-90s, due to a cage collapse on an SSB car) - Requirement for two door bars on drivers side (wreck circa 1999) - Requirements for two door bars both sides (another wreck, around 2004) Cage tubing sizes have changed over the years based on design requirements changes; anyone that compares this years book to, say, 1999 will find thicker tubing yet fewer weight brackets. Now, there are some design elements of the rollcage that can be grandfathered in for cars that have been previously logbooked*, but generally there is a minimum-required safety standard that all cars have to meet, regardless of initial logbook issuance. This car's requirements fall under GCR 9.4, "ROLL CAGES FOR GT AND PRODUCTION BASED CARS", page GCR 86 in the December PDF. Further, since it has the full windshield, it cannot take advantage of the "asymmetric" hoop design. Is the car going to be run with the targa top? Then it's considered an enclosed car. Without the Targa is "open top" regs. Per the discussions above, GCR 9.4.B.2.a clearly states, "Main hoops shall incorporate a diagonal brace", which this one has. However, GCR 9.4.B.2.b also clearly states, "Cars must incorporate a main hoop horizontal brace at the approximate level of the driver’s shoulders but not lower than the shoulder belt mounting point as described in section 9.3." This car does not have that required horizontal brace. GCR 9.4.C.1.c clearly states, "All open cars with a high front hoop and all closed cars except those competing in the T4, Improved Touring, Spec Miata, and B-Spec classes must incorporate a horizontal front hoop brace at the approximate level of the dashboard." This car does not yet have that required horizontal brace. I don't recall reading what the weight of your car is, but I'm assuming you'll fit into the 1701-2699 pound bracket. That requires 1.50x.095 or 1.625x.0080 minimum DOM mild steel. I do NOT recommend chromoly, simply because none of us generally have the ability to properly heat treat welded chromoly tubing. Stick with DOM mild steel. It's all fine and good that someone has signed off the car, and that you have not had any grief from anyone in subsequent annual inspections and events. When I'm initially inspecting a car and issuing a logbook, I'm quite careful and detailed and ensure everything is up to spec. However, I'll freely admit that when doing subsequent annual inspections I'm less careful, trusting prior scrutineers' inspections. So it's certainly probable that this has slipped through some scrutineers' eyes. Or, we've taken it for granted that since the car has been racing for seemingly forever the design must be fine. But just because it's been that way forever doesn't mean it meets the current regs. Maybe the regs have changed since it was initially inspected? Bottom line, based on very little info in this thread, I do not believe the current design meets the current SCCA GCR requirements. And while you've been perfectly fine racing it that way, you run the risk of someone casually looking inside and thinking, "hey, that's not right" and they pull you off the track for not meeting minimum safety requirements. Believe me, I've done it (stick your finger around the top of some production-car-based rollcages and you may find incomplete welds (yeah, I couldn't get up there), poor welding quality (well the last guy passed it!) and I've even seen people using JB Weld or body putty to make really bad welds look good. If I see that, I won't allow you on the track. I can't, it's not right. Finally, I read some comments above about this cage being built to FIA specs. That's a great start! However note that unless the cage is actually "FIA Certified" for its application, it is still required to meet SCCA minimum design requirements. And, if the cage actually is "FIA Certified" then the inspector needs to have that paperwork to use as a basis for issuing the logbook, and once issued that cage cannot be subsequently modified. So I don't think we're looking at any kind of FIA certification that applies here. Download the GCR, it's free. These are the minimum standards that have to be met. Always print it out and bring it to your cage builder, ensure he/she reads and understands it, and asks you if they have any questions. *Now, THAT ALL SAID...there exists in the GCR Appendix I which exists for cars logbooked prior to 2008 (what's the initial date of your first SCCA logbook issued?) At the time of writing, "GT" cars were considered to be those of tubeframe construction, so I suggest yours would use the Production regs. It's not a group of regs that I encourage anyone to use; after all, the latest rollcage regs have all been written in someone's blood, and these Appendix I allowance were a nod to old cars that may show up once in a while. Despite this, within Appendix I the horizontal bracing is not explicitly called out, and the accompanying drawings indicate that the horizontal bar is "recommended." "It is recommended that the vertical bars of the front hoop be connected by a horizontal bar at a point above the driver’s legs." I also point out that Appendix I states, "Specific installations are subject to approval by the Technical and Safety Inspectors at each event." So you're still maintain some risk of being excluded. Better keep a copy of the GCR with you and be prepared to plead your case. If your car has its initial logbook prior to 2008, you may choose to use a cage to either specs. However, note Appendix I was intended to grandfather legacy cars that were already built, ones that were not expected to be updated for competition. As such, the logbook goes with the cage, kinda like how the engine number goes with the chassis. If you replace and/or recreate that cage, you lose that logbook and must build your new cage to the latest requirements. Though, it's quite likely you can find a buddy locally to wink, wink, nod, nod re-stamp your new cage with the old number and pretend it's the original cage. That's up to your conscience, no one else will know except you two... I've been doing this for a while, long enough to know exactly who these regs were written from. For example, Jay Wright at the 1993(?) Runoffs was the impetus for the horizontal bar. We used to only install a half-width horizontal bar, from the driver's side to the diagonal, to keep the seat from moving backwards in a crash and allowing the driver's head to hit the diagonal element. We also used it for shoulder harness attachments. That's what was in Jay's SSB car when it hit the tire wall along the Road Atlanta front straight coming out of Turn 12. The car went airborne and landed on the roof. The diagonal along with the horizontal half-element moved out of the plane of the main hoop, allowing the main hoop to collapse sideways and the roof came "down" on Jay's head, making him a paraplegic until the day he died. He lived a good life, and did a lot of good things for racing (technical recommendations, scrutineering, developing an affordable H&NR, the Wright Device; he was actually a NASA rocket scientist) before eventually succumbing to complications from his injuries. As a result, we began requiring the horizontal to go all the way across and we added a diagonal within the rear hoop bracings. Bottom line, do you want to be out there among big-bore fast cars with a outdated cage? Again, your call. After all, in the end it's your ass on the line, not mine. I sign off on your max-built cage and then you wreck your car, I go to the worker party and have some beer. I sign off your minimum-built cage and you wreck your car, I still go to the worker party and have some beer. But we'll hoist one in your honor. I know this was a windy, heady, "harsh my mellow" post, and I apologize for those bored with it. But I do encourage well-built safety systems that exceed the minimum requirements. Greg |
| Heater Guy |
Dec 11 2018, 11:40 AM
Member ![]() ![]() Group: Members Posts: 74 Joined: 20-October 09 From: Walnut Creek, CA Member No.: 10,960 Region Association: Northern California |
Good morning! Just catching this thread, wanted to follow up. I am a Nationally-licensed SCCA scrutineer and a racer. First, what the regs were when the car was built*, or what someone may have approved in the past, is not relevant. You have to meet current GCR regs to run in SCCA Club Racing. The GCR is constantly updated and can be found here: https://www.scca.com/pages/cars-and-rules Rollcage regs have been fairly consistent over the last decade or so; major changes in recent years include: - Requirement for full-width main hoop bar (mid-90s, due to a cage collapse on an SSB car) - Requirement for two door bars on drivers side (wreck circa 1999) - Requirements for two door bars both sides (another wreck, around 2004) Cage tubing sizes have changed over the years based on design requirements changes; anyone that compares this years book to, say, 1999 will find thicker tubing yet fewer weight brackets. Now, there are some design elements of the rollcage that can be grandfathered in for cars that have been previously logbooked*, but generally there is a minimum-required safety standard that all cars have to meet, regardless of initial logbook issuance. This car's requirements fall under GCR 9.4, "ROLL CAGES FOR GT AND PRODUCTION BASED CARS", page GCR 86 in the December PDF. Further, since it has the full windshield, it cannot take advantage of the "asymmetric" hoop design. Is the car going to be run with the targa top? Then it's considered an enclosed car. Without the Targa is "open top" regs. Per the discussions above, GCR 9.4.B.2.a clearly states, "Main hoops shall incorporate a diagonal brace", which this one has. However, GCR 9.4.B.2.b also clearly states, "Cars must incorporate a main hoop horizontal brace at the approximate level of the driver’s shoulders but not lower than the shoulder belt mounting point as described in section 9.3." This car does not have that required horizontal brace. GCR 9.4.C.1.c clearly states, "All open cars with a high front hoop and all closed cars except those competing in the T4, Improved Touring, Spec Miata, and B-Spec classes must incorporate a horizontal front hoop brace at the approximate level of the dashboard." This car does not yet have that required horizontal brace. I don't recall reading what the weight of your car is, but I'm assuming you'll fit into the 1701-2699 pound bracket. That requires 1.50x.095 or 1.625x.0080 minimum DOM mild steel. I do NOT recommend chromoly, simply because none of us generally have the ability to properly heat treat welded chromoly tubing. Stick with DOM mild steel. It's all fine and good that someone has signed off the car, and that you have not had any grief from anyone in subsequent annual inspections and events. When I'm initially inspecting a car and issuing a logbook, I'm quite careful and detailed and ensure everything is up to spec. However, I'll freely admit that when doing subsequent annual inspections I'm less careful, trusting prior scrutineers' inspections. So it's certainly probable that this has slipped through some scrutineers' eyes. Or, we've taken it for granted that since the car has been racing for seemingly forever the design must be fine. But just because it's been that way forever doesn't mean it meets the current regs. Maybe the regs have changed since it was initially inspected? Bottom line, based on very little info in this thread, I do not believe the current design meets the current SCCA GCR requirements. And while you've been perfectly fine racing it that way, you run the risk of someone casually looking inside and thinking, "hey, that's not right" and they pull you off the track for not meeting minimum safety requirements. Believe me, I've done it (stick your finger around the top of some production-car-based rollcages and you may find incomplete welds (yeah, I couldn't get up there), poor welding quality (well the last guy passed it!) and I've even seen people using JB Weld or body putty to make really bad welds look good. If I see that, I won't allow you on the track. I can't, it's not right. Finally, I read some comments above about this cage being built to FIA specs. That's a great start! However note that unless the cage is actually "FIA Certified" for its application, it is still required to meet SCCA minimum design requirements. And, if the cage actually is "FIA Certified" then the inspector needs to have that paperwork to use as a basis for issuing the logbook, and once issued that cage cannot be subsequently modified. So I don't think we're looking at any kind of FIA certification that applies here. Download the GCR, it's free. These are the minimum standards that have to be met. Always print it out and bring it to your cage builder, ensure he/she reads and understands it, and asks you if they have any questions. *Now, THAT ALL SAID...there exists in the GCR Appendix I which exists for cars logbooked prior to 2008 (what's the initial date of your first SCCA logbook issued?) At the time of writing, "GT" cars were considered to be those of tubeframe construction, so I suggest yours would use the Production regs. It's not a group of regs that I encourage anyone to use; after all, the latest rollcage regs have all been written in someone's blood, and these Appendix I allowance were a nod to old cars that may show up once in a while. Despite this, within Appendix I the horizontal bracing is not explicitly called out, and the accompanying drawings indicate that the horizontal bar is "recommended." "It is recommended that the vertical bars of the front hoop be connected by a horizontal bar at a point above the driver’s legs." I also point out that Appendix I states, "Specific installations are subject to approval by the Technical and Safety Inspectors at each event." So you're still maintain some risk of being excluded. Better keep a copy of the GCR with you and be prepared to plead your case. If your car has its initial logbook prior to 2008, you may choose to use a cage to either specs. However, note Appendix I was intended to grandfather legacy cars that were already built, ones that were not expected to be updated for competition. As such, the logbook goes with the cage, kinda like how the engine number goes with the chassis. If you replace and/or recreate that cage, you lose that logbook and must build your new cage to the latest requirements. Though, it's quite likely you can find a buddy locally to wink, wink, nod, nod re-stamp your new cage with the old number and pretend it's the original cage. That's up to your conscience, no one else will know except you two... I've been doing this for a while, long enough to know exactly who these regs were written from. For example, Jay Wright at the 1993(?) Runoffs was the impetus for the horizontal bar. We used to only install a half-width horizontal bar, from the driver's side to the diagonal, to keep the seat from moving backwards in a crash and allowing the driver's head to hit the diagonal element. We also used it for shoulder harness attachments. That's what was in Jay's SSB car when it hit the tire wall along the Road Atlanta front straight coming out of Turn 12. The car went airborne and landed on the roof. The diagonal along with the horizontal half-element moved out of the plane of the main hoop, allowing the main hoop to collapse sideways and the roof came "down" on Jay's head, making him a paraplegic until the day he died. He lived a good life, and did a lot of good things for racing (technical recommendations, scrutineering, developing an affordable H&NR, the Wright Device; he was actually a NASA rocket scientist) before eventually succumbing to complications from his injuries. As a result, we began requiring the horizontal to go all the way across and we added a diagonal within the rear hoop bracings. Bottom line, do you want to be out there among big-bore fast cars with a outdated cage? Again, your call. After all, in the end it's your ass on the line, not mine. I sign off on your max-built cage and then you wreck your car, I go to the worker party and have some beer. I sign off your minimum-built cage and you wreck your car, I still go to the worker party and have some beer. But we'll hoist one in your honor. I know this was a windy, heady, "harsh my mellow" post, and I apologize for those bored with it. But I do encourage well-built safety systems that exceed the minimum requirements. Greg Thanks for the explanation. Ron SFR. Pit Fire 09 T2 |
naro914 Show me your roll cage to suspension tower bracing Oct 26 2018, 08:33 AM
Mr. Olympic Blue 2 You Good luck with the refresh Bob! Oct 26 2018, 12:33 PM
Chi-town That style cross brace in the halo will collapse i... Oct 26 2018, 01:11 PM
naro914 Nice...I could use that rotisserie... Oct 26 2018, 01:27 PM
Brett W If I were doing the chassis, I would cut the curre... Oct 27 2018, 08:06 PM
Heater Guy
with all the work we're doing on Papa Smurf, ... Nov 3 2018, 03:13 PM
Krieger Check out my F-914 build in my signature. I have C... Nov 7 2018, 12:20 AM
Brett W That cage is of questionable legality for SCCA and... Nov 8 2018, 07:35 PM
ChrisFoley RE: Show me your roll cage to suspension tower bracing Nov 9 2018, 09:20 AM
mlindner Here's mine Bob. Best, Mark Nov 17 2018, 08:08 PM
mlindner One more shot of the passenger compartment before ... Nov 17 2018, 08:34 PM
campbellcj Here is a car I saw (I think) at a VARA event last... Nov 18 2018, 09:29 AM
Heater Guy
with all the work we're doing on Papa Smurf, ... Dec 4 2018, 07:41 PM
naro914
This cage is legal for SCCA. Just removed it fro... Dec 4 2018, 08:01 PM
Heater Guy
This cage is legal for SCCA. Just removed it fr... Dec 4 2018, 08:05 PM
naro914 ^^ah. thanks Dec 4 2018, 08:06 PM
ChrisFoley Without a full width main hoop crossbar that cage ... Dec 5 2018, 06:12 AM
naro914 That’s what my cage crossbar is like and it’s ... Dec 5 2018, 07:31 AM
ChrisFoley
That’s what my cage crossbar is like and it’s... Dec 5 2018, 07:35 AM
naro914
That’s what my cage crossbar is like and it’... Dec 5 2018, 08:40 AM
Heater Guy
[quote name='ChrisFoley' post='2671242' date='Dec... Dec 5 2018, 03:30 PM
Heater Guy
[quote name='naro914' post='2671256' date='Dec 5 ... Dec 5 2018, 03:51 PM
Chi-town Then the Tech inspector wasn't doing his job.
... Dec 5 2018, 09:53 AM
naro914
Then the Tech inspector wasn't doing his job.... Dec 5 2018, 02:33 PM
naro914 Recommended, not required.
We can’t put a knee b... Dec 5 2018, 03:59 PM
campbellcj
We can’t put a knee ... Dec 5 2018, 06:17 PM
brant agreed with Chris
knee bars go inside the dash an... Dec 6 2018, 11:03 AM
Brett W Yup, you need a better fabricator. Proper dash ba... Dec 9 2018, 11:14 AM
stownsen914 Definitely want a dash bar and a horizontal bar ac... Dec 9 2018, 11:00 PM
brant
Definitely want a horizontal bar across middle or... Dec 10 2018, 11:57 AM
naro914 OK then, can someone show pictures of their knee b... Dec 10 2018, 07:15 AM
Jetsetsurfshop My knee bar is almost touching the lower part of t... Dec 10 2018, 08:36 AM
ChrisFoley Forward hoops which penetrate the stock dash are g... Dec 10 2018, 09:22 AM
brant Ours: Dec 10 2018, 09:59 AM
Brett W Sounds like your seat is pushed too far forward or... Dec 10 2018, 11:31 AM
naro914 Nadine sits with the seat as far forward as she ca... Dec 10 2018, 11:43 AM
Jetsetsurfshop My knee bar, from Tangerine. Dec 10 2018, 01:33 PM
Brett W Too low, Nadine is now an amputee. That design wo... Dec 10 2018, 09:15 PM
Chi-town @GregAmy - Thank you for the post and clarificati... Dec 11 2018, 09:14 AM
ThePaintedMan :agree: Greg nailed it. Which also makes me re-thi... Dec 11 2018, 10:53 AM
sixnotfour I cut the dash so the knee bar would be higher...... Dec 11 2018, 12:16 PM
GregAmy The orange historics car has a Foley cage from ... Dec 11 2018, 12:44 PM
naro914 Just met with my fabricator and he had already pla... Dec 12 2018, 11:29 AM
Heater Guy
Just met with my fabricator and he had already pl... Dec 12 2018, 12:28 PM
naro914
It must be realized that, for one reason or anoth... Dec 12 2018, 01:00 PM
Heater Guy
It must be realized that, for one reason or anot... Dec 12 2018, 01:14 PM
GregAmy Agree. Monthly SCCA Fast Tracks can sometimes driv... Dec 12 2018, 01:24 PM
Brett W
Plus double row "NASCAR" style door bar... Dec 13 2018, 07:30 AM
Chi-town
Apparently not, because he chose the second worse... Dec 13 2018, 09:02 AM
GregAmy There are a lot of different designs that people u... Dec 13 2018, 10:24 AM
Brett W I understand what he is talking about. In order f... Dec 13 2018, 09:20 AM
mlindner Here's mine, I'm six foot, never a problem... Dec 16 2018, 05:50 AM
Beechhousegarage Working on a T45 cage by Custom Cages UK,
Attachme... Apr 20 2019, 01:48 PM
Beechhousegarage another view Apr 20 2019, 01:50 PM
GregAmy Is that cage above being built to a specific sanct... Apr 20 2019, 07:34 PM
Beechhousegarage
Is that cage above being built to a specific sanc... Apr 21 2019, 10:56 AM
GregAmy For reference, I'm an SCCA scrutineer.
What c... Apr 21 2019, 02:15 PM
GregAmy Just a quick follow up that I forgot to mention.
... Apr 21 2019, 02:31 PM
Beechhousegarage Thanks Greg!
I may have been a little stubbor... Apr 21 2019, 05:39 PM
Beechhousegarage RE: Show me your roll cage to suspension tower bracing Apr 21 2019, 05:42 PM
GregAmy :beer2: Apr 21 2019, 07:53 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 11:53 AM |
