E- Brake spring behind seat, How is it anchored ? |
jim_hoyland |
Dec 16 2018, 04:43 PM
Get that VIN ? Group: Members Posts: 9,321 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
The eBrake lever hasn’t been operating smoothly when releasing. At the firewall where the cables attach to the mechanism there is a short spring. It was not attached at the rear end; where does the spring attach ?
Attached image(s) |
bbrock |
Dec 16 2018, 07:04 PM
The tab with the hole is for mounting the cover plate. If you peek under the tab, you should see a hole between the cable tubes which is where the spring goes.
Lo-Fi Version | Time is now: 11th June 2024 - 05:13 AM |
