| yeahmag |
Dec 17 2018, 01:36 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,485 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California
I've never had a Stage 1 clutch in a Type 4. The KEP Stage 1 (modified Sachs) feels really heavy on the pedal. I'm OK with it as long as nothing is wrong. Anybody had the same?
I imagine if this is "normal", I should switch to a Delrin pulley... Attached thumbnail(s) |
| SirAndy |
Dec 17 2018, 01:46 PM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,517 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Are you sure the throw is adjusted properly?
I had KEP Stage I, II and III clutches and i currently run a special made one-off KEP clutch on my 3.6L and while they do feel a bit firmer, i never had any of them feel heavy. Once adjusted properly, you should feel a very distinct point where the clutch disengages and once past that point, the pedal should move freely without much force needed to hold it. (IMG:style_emoticons/default/idea.gif) |
yeahmag Stage 1 Clutch Kit - Pedal HEAVY! Dec 17 2018, 01:36 PM
yeahmag It's adjusted a bit low at this point. I don... Dec 17 2018, 01:48 PM
yeahmag Adjusting it to the correct range definitely helpe... Dec 17 2018, 07:20 PM
SirAndy @yeahmag
Did you ever get this to work well?
:i... Apr 14 2019, 10:44 PM
yeahmag Changed the clutch cable from a Terry to a Cofle a... Apr 14 2019, 10:54 PM
'73-914kid Terry cables do not have the plastic sheaths in th... Apr 15 2019, 09:37 AM
jkb944t
Terry cables do not have the plastic sheaths in t... Apr 15 2019, 10:31 AM
yeahmag It would probably be tough if it's in the car ... Apr 15 2019, 11:11 AM
jcd914 Some cables have the brand on the black cable hous... Apr 15 2019, 12:48 PM![]() ![]() |
Lo-Fi Version | Time is now: 17th September 2026 - 01:25 PM |
