Oil Cooler Seals and AC belt, Replacement Advice |
jdamiano |
Dec 22 2018, 05:52 PM
Member Group: Members Posts: 335 Joined: 18-March 18 From: Jacksonville Member No.: 21,981 Region Association: South East States |
I’m about to start a project and wanted to check with the experts before I got in over my head. I need to replace my oil cooler seals and A/C belt. Looks like I can do it engine in. Please let me know if I’m missing something.
Drain Oil Pull tin underneath passenger cylinders. Remove metal heat duct Remove oil filter Remove A/C idler pulley and bracket Remove passenger side cooling tin between engine and firewall. Remove oil cooler replace gaskets and reinstall cooler Remove alternator belt Unbolt fan and snake A/C belt over pulley Put it all back together with new alternator belt as well. Any input appreciated. Nothing on YouTube for this one! |
ClayPerrine |
Dec 22 2018, 08:22 PM
Life's been good to me so far..... Group: Admin Posts: 15,503 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
I’m about to start a project and wanted to check with the experts before I got in over my head. I need to replace my oil cooler seals and A/C belt. Looks like I can do it engine in. Please let me know if I’m missing something. Drain Oil Pull tin underneath passenger cylinders. Remove metal heat duct Remove oil filter Remove A/C idler pulley and bracket Remove passenger side cooling tin between engine and firewall. Remove oil cooler replace gaskets and reinstall cooler Remove alternator belt Unbolt fan and snake A/C belt over pulley Put it all back together with new alternator belt as well. Any input appreciated. Nothing on YouTube for this one! Here's the directions... Change oil cooler seals with motor in the car. To change the AC belt, just remove the front tin, unbolt the fan, and change the belt. Reassembly is the reverse of disassembly. |
Lo-Fi Version | Time is now: 2nd June 2024 - 11:55 PM |
