Valve adjustment, Doesn’t feel right? |
John90290 |
Dec 24 2018, 01:59 PM
Member Group: Members Posts: 93 Joined: 4-March 18 From: Ventura, CA Member No.: 21,937 Region Association: None |
Adjusting the valves on my 1975 1.8 that I just put new pistons in. I’m going through the process as outlined on a few manuals but for some reason it doesn’t feel right? I’ve never done this before so the manuals I have don’t really have good pictures and the videos and such just say go to tdc and adjust. I get to the tdc mark but feel I need to turn it a bit more to get the valves on the number one to fully close. Also when I move on the the other cyclyndsrs after moving the crank 180 degrees, the ones I previously adjusted seem loose. Not sure if thes makes sense. I don’t want to get it back in the car and have it not run.
I’ve seen valve adjustment discussions on this forum before but couldn’t find them doing the search. |
914Sixer |
Dec 24 2018, 03:02 PM
914 Guru Group: Members Posts: 8,909 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Check to see if you have the CORRECT fan housing. 1.7 and 2.0 timing marks are different than 1.8. 1.8 is 7.5 degrees BTDC(Before Top Dead Center) @ 800-900 rpm.
Lo-Fi Version | Time is now: 16th June 2024 - 09:08 AM |
