Valve adjustment, Doesn’t feel right? |
John90290 |
Dec 24 2018, 01:59 PM
Member Group: Members Posts: 93 Joined: 4-March 18 From: Ventura, CA Member No.: 21,937 Region Association: None |
Adjusting the valves on my 1975 1.8 that I just put new pistons in. I’m going through the process as outlined on a few manuals but for some reason it doesn’t feel right? I’ve never done this before so the manuals I have don’t really have good pictures and the videos and such just say go to tdc and adjust. I get to the tdc mark but feel I need to turn it a bit more to get the valves on the number one to fully close. Also when I move on the the other cyclyndsrs after moving the crank 180 degrees, the ones I previously adjusted seem loose. Not sure if thes makes sense. I don’t want to get it back in the car and have it not run.
I’ve seen valve adjustment discussions on this forum before but couldn’t find them doing the search. |
iankarr |
Dec 24 2018, 06:09 PM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,482 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
You sure you have solid lifters? Hydraulic ones don’t get tight the way solid ones do. If you pull back on the rocker and it feels springy....
Lo-Fi Version | Time is now: 16th June 2024 - 07:43 AM |
