Valve adjustment, Doesn’t feel right? |
John90290 |
Dec 24 2018, 01:59 PM
Member Group: Members Posts: 93 Joined: 4-March 18 From: Ventura, CA Member No.: 21,937 Region Association: None |
Adjusting the valves on my 1975 1.8 that I just put new pistons in. I’m going through the process as outlined on a few manuals but for some reason it doesn’t feel right? I’ve never done this before so the manuals I have don’t really have good pictures and the videos and such just say go to tdc and adjust. I get to the tdc mark but feel I need to turn it a bit more to get the valves on the number one to fully close. Also when I move on the the other cyclyndsrs after moving the crank 180 degrees, the ones I previously adjusted seem loose. Not sure if thes makes sense. I don’t want to get it back in the car and have it not run.
I’ve seen valve adjustment discussions on this forum before but couldn’t find them doing the search. |
jvmarino |
Dec 24 2018, 10:50 PM
Member Group: Members Posts: 81 Joined: 22-March 09 From: Baltimore Member No.: 10,188 Region Association: None |
Make sure you are at TDC for the compression stroke. If you are 360 degrees out, the valves will seem really funky and the engine will not run at all. Made that mistake the first time, but never again.
Lo-Fi Version | Time is now: 16th June 2024 - 03:57 AM |
