1970 914 project |
1970 914 project |
1970-1914 |
Jun 28 2018, 04:35 PM
Member Group: Members Posts: 97 Joined: 3-June 18 From: Vancouver Member No.: 22,186 Region Association: Canada |
I recently bought this partially restored 1970 914 shell off Craigslist for a pretty decent price. I have been looking for quite a while and there are only so many around in the Vancouver BC area and most are quite rusty if they are not $$$$$. The good news is most of the gross nasty metal work was already completed so in that regard I’m pretty far ahead for a project. Also came with quite a few decent parts - some I will use and some I will sell off to get the parts I actually need.
Not sure what I will do about engine choice.... would really like to do a 6 but based on cost I may end up doing a v8 or Subaru? Not sure but luckily I have a ton of other work to do on the rest of the car while I make up my mind. EDIT: V8 it is - Purchased most of a Renegade SBC kit (IMG:style_emoticons/default/smile.gif) The Formula Vee wheels were just way too skinny for the flares so they have been sold and I picked up a set of chrome 15x6 and 15 x7 cookie cutters. Not sure if they will be wide enough either to look correct but the deal was great and they will at least allow me to do the 5 bolt conversion. I have one side of the rear suspension all apart and the rear axle stub out - looks like it is the early style with the raised bosses in place for 5 lug. I will update with some pics once that is done and the trailing arm is back together. |
jimkelly |
Dec 23 2018, 08:10 AM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
that Fitech efi setup looks sweet. i'm gonna run rams horns instead of shorty headers.
according to this video, rams horns are fine to 5200 rpm. https://www.youtube.com/watch?v=qe9ke0rQlT8 |
mgp4591 |
Dec 24 2018, 11:25 PM
914 Guru Group: Members Posts: 5,378 Joined: 1-August 12 From: Salt Lake City Ut Member No.: 14,748 Region Association: Intermountain Region |
that Fitech efi setup looks sweet. i'm gonna run rams horns instead of shorty headers. according to this video, rams horns are fine to 5200 rpm. https://www.youtube.com/watch?v=qe9ke0rQlT8 They make ram horns that have a 2 1/2" outlet that's probably more flow than you'd need - they came with the high hp Corvette smallblocks. The small valve heads will get you to that 5200 rpm that the ram horns are good to without a problem. It sounds like a good combination all around. |
Lo-Fi Version | Time is now: 29th May 2024 - 02:28 AM |
