| 914_7T3 |
Dec 24 2018, 03:10 PM
Please forgive me, I'm new to all of this! ![]() ![]() ![]() Group: Members Posts: 1,894 Joined: 3-April 17 From: Los Angeles, CA Member No.: 20,991 Region Association: Southern California
Used the clips that come with The Genuine Porsche OEM trim kit From Sierra Madre and important to note that they do not break as easily as the aftermarket ones. Drawback is that they were one clip short in the package. Luckily our 914World Designated Windshield Installer had a spare.
![]() Once clips were in, a Butyl Primer was used as recommended in the below thread. http://914world.com/bbs2/index.php?showtopic=312146 ![]() Windshield was warmed up in the sun prior to install. ![]() 5/16 Butyl Primer is used and the glass positioned and seated. ![]() ![]() Snap in the trim clips and you're good to go. ![]() The windshield I am using is a Sekurit from Finland and it seems to not sit 100% flush in some areas. As a result, it takes some finessing to make sure there is enough clearance for the trim to notch comfortably into the clips. The takeaway here is to use a professional installer if you do not have the suction tool or have not done a windshield install before! |
| iankarr |
Dec 25 2018, 03:09 PM
The wrencher formerly known as Cuddy_K ![]() ![]() ![]() ![]() Group: Members Posts: 2,595 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region
I removed and replaced the windshield on my '73. Pretty straightforward if you go sloooowly and carefully. Though the nice thing about hiring a pro is that it's on them if they break it;). If I lived in SoCal, I def would've done as @914_7T3 did. The hardest / scariest part is pressing the corners into the butyl, which is when the windshield seems most prone to cracking.
Here are a few pics. You can see where I put the butyl primer. I was much neater than I needed to be, since I'm totally OCD. In reality the butyl / glass / trim covers the whole channel. Also a pic of the primer I used. Put the butyl "seam" on the bottom and butted the ends. One other tip which I'm pretty sure I read here on the world, though I can't seem to find the link... test fit the glass in-place before you put the butyl down using suction cups (cheeep at HF), the spacer blocks and a helper. Line it up/down/left/right so that it's sitting evenly in the channel and put a piece of blue painter's tape in the middle of each edge, straddling the glass and the frame (top, bottom, left, right). Use a sharpie to draw across the space between the glass and body and cut the tape in-place using a razor blade. The tape and sharpie marks allow you to line up the glass perfectly before you set it down. Once the glass touches the butyl, you can't move it much, so it's important to it place it exactly right before you commit. ![]() |
914_7T3 Windshield Installation: Dec 24 2018, 03:10 PM
914Sixer Don't see bottom windshield spacer ? Dec 24 2018, 03:20 PM
914_7T3
There... Dec 24 2018, 03:22 PM
cuddy_k Nice write up...and glad the glass is in! Dec 24 2018, 05:14 PM
HansJan Installing the windshield is a lot easier then it ... Dec 24 2018, 09:19 PM
buck toenges Can you add the chrome trim pieces on later or doe... Dec 24 2018, 10:46 PM
HansJan
Can you add the chrome trim pieces on later or do... Dec 24 2018, 11:21 PM
Tdskip Thanks for the write up and discussion, very helpf... Dec 24 2018, 11:38 PM
Larmo63 I assume you used Ruffino to install your windshie... Dec 25 2018, 11:56 AM
914_7T3
I assume you used Ruffino to install your windshi... Dec 26 2018, 08:08 PM
IronHillRestorations A couple body & glass guys I know recommended ... Dec 25 2018, 01:47 PM
Tdskip Anyone have a close up picture of how the clip and... Dec 26 2018, 08:05 AM
mepstein Primer is just used to help the butyl tape stick b... Dec 26 2018, 08:18 AM
Tdskip
Primer is just used to help the butyl tape stick ... Dec 26 2018, 09:42 AM
Costa05 Great advise on this thread. Thx. I am planning to... Dec 26 2018, 10:02 AM
Mikey914
Great advise on this thread. Thx. I am planning t... Jan 6 2019, 12:17 PM
buck toenges 914 rubber includes instructions on their butyl ta... Jan 2 2019, 07:48 PM
cuddy_k On the CRL primer, the dabber is integrated into t... Jan 2 2019, 09:15 PM
nivekdodge I’ve been been reading a lot of these glass inst... Oct 28 2022, 07:38 AM
bbrock
I’ve been been reading a lot of these glass ins... Oct 28 2022, 07:48 AM
Robarabian It flexes. The urethane of today's cars is ver... Oct 28 2022, 07:21 PM
bkrantz
I’ve been been reading a lot of these glass ins... Oct 28 2022, 08:04 PM
930cabman
I’ve been been reading a lot of these glass in... Nov 2 2022, 05:07 AM
914werke :agree: These cars were flexi-flyers when new (esp... Oct 28 2022, 10:32 AM
mepstein Yea. People want to modernize the install and the ... Oct 28 2022, 02:22 PM
nivekdodge Thanks guys
Kevin Oct 28 2022, 02:51 PM
VaccaRabite I've had my windshield glued in with urethane ... Nov 2 2022, 06:00 AM
930cabman
I've had my windshield glued in with urethane... Nov 2 2022, 06:25 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 06:41 PM |
