| Tdskip |
Dec 27 2018, 08:16 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,755 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None
I have a couple of these hanging around and I’m not sure if they are all interchangeable or not?
I thought there were some differences between the different systems (1.7 vs 2.0) but wanted to ask. As of now everything is carefully associated with the complete system that was part of. Thanks! |
| JeffBowlsby |
Dec 27 2018, 09:42 AM
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,222 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None
No, not interchangeable.
For 914 2.0L's there are two different MPS's, and their PNs end in 037 (1973-only), and 043 (1974-76). These are physically the same internally but are calibrated differently for compatibility with their respective ECU's, which are also different. The 914 1.7L has a single MPS, PN ending in 049. It is physically different internally and calibrated differently, from the 2.0L MPS's for compatibility with the 1.7L ECU's. |
| euro911 |
Dec 27 2018, 02:00 PM
Retired & living the dream. God help me if I wake up! ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,937 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California
No, not interchangeable. Jeff, how do us guys with 1911 motors deal with the 049 MPS issue? I have an Innovate LM-2 AFR meter, so that should help with the adjustment? (IMG:style_emoticons/default/confused24.gif) For 914 2.0L's there are two different MPS's, and their PNs end in 037 (1973-only), and 043 (1974-76). These are physically the same internally but are calibrated differently for compatibility with their respective ECU's, which are also different. The 914 1.7L has a single MPS, PN ending in 049. It is physically different internally and calibrated differently, from the 2.0L MPS's for compatibility with the 1.7L ECU's. I plan to keep the 1.7L FI components but use green 2.0L injectors. I also have a set of 1.8L injectors, but think the 2.0L will be closer than those. |
Tdskip Are the various years MPS interchangeable? Dec 27 2018, 08:16 AM
TravisNeff Yes they are, you will have to re re calibrate the... Dec 27 2018, 08:28 AM
BeatNavy There are differences. You can generally get a ca... Dec 27 2018, 08:37 AM
Tdskip Thanks gentlemen.
I assume there is a part number... Dec 27 2018, 08:48 AM
BeatNavy
Thanks gentlemen.
I assume there is a part numbe... Dec 27 2018, 08:53 AM
TravisNeff 1.7L 1970 - 1973
VW/Porsche part number: 022 906 0... Dec 27 2018, 09:01 AM
Tdskip Thanks guys, appreciate the info! Dec 27 2018, 09:05 AM
Tdskip Thanks Jeff (and all) Dec 27 2018, 10:34 AM
Bleyseng The only difference to adjusting a early 1.7 one t... Dec 27 2018, 01:23 PM
914_teener Tom,
The MPS that I sold you is correct for a 2.0... Dec 27 2018, 01:43 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 01:46 PM |
