Static Timing Help Needed, Getting Constant Voltage |
Ansbacher |
Jan 6 2019, 02:53 PM
Senior Member Group: Members Posts: 689 Joined: 4-July 14 From: Tampa Bay, Florida Member No.: 17,589 |
I am in the process of installing a 1.8L 205AA Vacuum Distributor in my dual carb setup. I am initially trying to static time it, but no matter where I turn the distributor, I get a constant 12V on my meter. It never goes to zero. I can see the points open and close but the voltage remains all the time. What's wrong here? Is there something I need to disconnect inside the 205AA dizzy since I am not fuel injected? Very puzzled and need HEEEELP !!!! Thanks.
Ansbacher |
Mark Henry |
Jan 6 2019, 03:20 PM
I am in the process of installing a 1.8L 205AA Vacuum Distributor in my dual carb setup. I am initially trying to static time it, but no matter where I turn the distributor, I get a constant 12V on my meter. It never goes to zero. I can see the points open and close but the voltage remains all the time. What's wrong here? Is there something I need to disconnect inside the 205AA dizzy since I am not fuel injected? Very puzzled and need HEEEELP !!!! Thanks. Ansbacher Do you have the light on coil -? Points or pertronix? IIRC some electronic points put out an odd signal and can only be set with a strobe. |
Lo-Fi Version | Time is now: 2nd June 2024 - 11:26 PM |
