Where to source -- Heater Cable End Clamp, Tunnel is pinched so have to diy a solution |
moldygreg |
Jan 10 2019, 10:30 PM
Stay Golden Group: Members Posts: 135 Joined: 13-December 12 From: Seattle Member No.: 15,253 Region Association: Pacific Northwest |
Hi all-
After an hour of doing battle trying to install a lovely new heater cable from 914 Rubber, I discovered the tunnel must be pinched at the firewall. I can get a cable through, but not with the end crimp. Where can I source a Heater cable end clamp? And what size(s) do I need. I see bicycle cable caps, but that's not large nor robust enough. Many thanks in advance- Greg |
mepstein |
Jan 10 2019, 10:48 PM
914-6 GT in waiting Group: Members Posts: 19,308 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I had a similar issue so I bent the tube just a little bit to lessen the curvature. I inserted a Phillips screwdriver in the tube and gave it a little nudge. That and lubing the cable made it work. You can also trim the solid end crimp by a couple mm so it will make the curve but still have enough length to be secured.
Lo-Fi Version | Time is now: 4th June 2024 - 11:05 AM |
