Best rear wheel/stub axle bearing, Bearing renew. |
914Toy |
Jan 8 2019, 12:39 PM
Senior Member Group: Members Posts: 718 Joined: 12-November 17 From: Laguna beach Member No.: 21,596 Region Association: Southern California |
What is recommended choice here for trailing arm rear wheel/stub axle bearing - there are two available at Pelican Parts: FAG @ $37.50 with four star rating and SKF @ $75.00 with three star rating?
90quattrocoupe |
Jan 17 2019, 03:55 PM
Member Group: Members Posts: 208 Joined: 4-November 16 From: Long Beach, CA. Member No.: 20,561 Region Association: Southern California |
I have been using a hub tool I bought many moons ago.
I would like to add one thing. Back in the day, bearings from the VAG dealers used to come with a little packet of Molybdenum Disulfide paste. You would use in on the bore of the hub, before inserting the bearing. Since that time, I have used the paste on both the hub carrier bore and on the hub itself. If you don't have any MD paste, you can use copper slip. I have never had a bearing or hub spin in the bores. But I find it a little easier to remove both later down the road when the bearing needs to be replaced. Greg W. |
Lo-Fi Version | Time is now: 8th June 2024 - 01:11 AM |
