| Ansbacher |
Jan 18 2019, 06:22 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 689 Joined: 4-July 14 From: Tampa Bay, Florida Member No.: 17,589 |
Car = '74 2.0 Liter, Dual Dellorto Carbs
For years I have been 'adequately" running an 009 mechanical only distributor. Finally took the pervasive advice out there to go with a vacuum advance dizzy from a 1.8L 914. Since only one of my Dellorto carbs had an existing vacuum port (ported type), I had to drill a port in my other one (no problem there). I used good quality anti-pulse valves in the lines and measured a maximum vacuum of 12 inches of mercury with partial throttle. Installed the 1.8 dizzy and set the timing, first without the vacuum lines attached. To satisfy my usual 30-32 degrees at 3500 RPM, the idle timing had to be at about 5-6 degrees (quite low for my setup which is happier at about 10 degrees. When I attached the vacuum lines my timing at 3500 RPM went sky high into the 40s. This seems way too high. Is this normal? Overall, I found the car to run better without the vacuum attached and the carbs plugged off. Am I doing something wrong here? I don't like the numbers I am getting. Everyone said this was the way to go with carbs, but I am not seeing results. Advice appreciated. Ansbacher |
| Mark Henry |
Jan 20 2019, 09:42 AM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
I've had a couple guys ask about the linkage, nice bit of kit.
https://www.thesamba.com/vw/classifieds/det....php?id=2079800 |
Ansbacher Giving Up On Vacuum Advance Jan 18 2019, 06:22 PM
nditiz1 Ditch that distributor and get the correct one for... Jan 18 2019, 11:11 PM
pete000 The 123 Dist is the way to go and no need for vac ... Jan 19 2019, 01:15 AM
Tbrown4x4 I'll be watching this with interest. I'm g... Jan 19 2019, 03:57 AM
nditiz1 I can't find the diagram right now, but someon... Jan 19 2019, 07:57 AM
BK911 I've been running an 009 with carbs on a 1.7 f... Jan 19 2019, 08:17 AM
nditiz1
I've been running an 009 with carbs on a 1.7 ... Jan 19 2019, 08:22 AM
Rand
I've been running an 009 with carbs on a 1.7 ... Jan 28 2019, 02:16 PM
72hardtop
I've been running an 009 with carbs on a 1.7... Jan 28 2019, 08:52 PM
tmessenger SVDA 034 here's what they say for timing: Use... Jan 19 2019, 09:13 AM
cgnj How much vacuum @ idle? How much @ 3k?
7.5 degrees... Jan 19 2019, 10:10 AM
Ansbacher
7.5 degree... Jan 19 2019, 03:05 PM
tmessenger Mechanical advance springs fatigue with age, with ... Jan 20 2019, 09:50 AM
914_teener I went through a tremendous amount of effort to fi... Jan 19 2019, 04:14 PM
pete000 I love my blue tooth programmable 123 so easy and ... Jan 19 2019, 04:35 PM
porschetub My research indicated the anti pulse valve is only... Jan 19 2019, 08:14 PM
Mark Henry Engine I just built for a customer, 914 2056cc wi... Jan 19 2019, 10:13 PM
Ansbacher Answers to some questions posed of me:
Yes, I am ... Jan 20 2019, 11:33 AM
r_towle Based upon what is going on, and your last questio... Jan 20 2019, 07:44 PM
72hardtop Don't attempt to 'T' the lines togethe... Jan 22 2019, 03:00 AM
Ansbacher
Don't attempt to 'T' the lines togeth... Jan 22 2019, 12:02 PM
72hardtop
Don't attempt to 'T' the lines toget... Jan 22 2019, 01:15 PM
IronHillRestorations One thing I forgot to mention is that the 1.8 dist... Jan 22 2019, 06:48 AM
Red72 Jumping in here, and I'm sorry to hijack it so... Jan 28 2019, 11:21 AM
tmessenger I went through this with a Triumph TR3 a couple of... Jan 28 2019, 12:40 PM
Rand Did you just suggest that you can create so much h... Jan 28 2019, 09:05 PM
72hardtop
Did you just suggest that you can create so much ... Jan 29 2019, 02:42 PM
Rand Let me take this second to say that I respect Joe ... Jan 28 2019, 09:21 PM
MarkV No doubt fuel injection is better. Many of us have... Jan 28 2019, 09:22 PM
914_teener Ok....I'm an EFI guy so for carbs it's th... Jan 29 2019, 04:30 PM
72hardtop
Ok....I'm an EFI guy so for carbs it's t... Jan 29 2019, 05:04 PM
914_teener https://web.archive.org/web/20001007043902/...ch/d... Jan 29 2019, 04:49 PM
914_teener Well then another dumb bunch of questions:
Isn... Jan 29 2019, 06:49 PM
72hardtop Corrected. Got ahead of myself there. Ported vac a... Jan 30 2019, 10:46 PM
tmessenger Ported vacuum with vac port covered by the throttl... Jan 31 2019, 08:23 AM
cgnj
Ported vacuum with vac port covered by the thrott... Jan 31 2019, 08:31 PM
tmessenger There are 11 years of knowledge in those 99 pages.... Jan 31 2019, 10:06 PM
72hardtop
Ported vacuum with vac port covered by the thrott... May 8 2019, 03:54 PM
72hardtop You can garner a lot from that thread with the fir... Jan 31 2019, 11:18 PM
tmessenger 72hardtop
Sounds like we have very similar engine... Feb 1 2019, 01:28 PM
72hardtop
72hardtop
Sounds like we have very similar engin... May 8 2019, 03:47 PM![]() ![]() |
Lo-Fi Version | Time is now: 16th April 2026 - 10:36 PM |
