| EdwardBlume |
May 19 2003, 10:02 PM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,340 Joined: 2-January 03 From: SLO Member No.: 81 Region Association: Central California
After hard driving at the AX School this weekend, the car is backfiring slightly under deceleration in gear. Valve adjustment time?
Also, on the drive home, at 50-70 the steering was rattling hard after turns then it would smooth out in the straights. Turn again, rattling, then smooth out. Any ideas what these things could be? |
| need4speed |
May 20 2003, 09:21 AM
Member ![]() ![]() Group: Members Posts: 339 Joined: 11-April 03 From: Arroyo Grande, CA Member No.: 564 |
backfiring on decelleration is, in my experience, most often an exhaust leak.
Test: Run the engine cold. Cover both tailpipes so that no exhaust can escape. If the engine dies, then either the leak is very small, or non existent. If the engine keeps running, you'll probably also hear a loud hiss. That's your leak. |
Rob Ways Technical Questions May 19 2003, 10:02 PM
Brad Roberts No idea.. but I will be down this week. We can tak... May 19 2003, 10:05 PM
Bleyseng What kind of fuel system, FI or Carbs?
Look at you... May 19 2003, 10:07 PM
ChrisReale Check your wheel bearings and make sure the wheels... May 19 2003, 10:36 PM
Rob Ways Brad, now that I think about it, I noticed that bo... May 19 2003, 10:36 PM
Brad Roberts See.. even when I have NO idea.. I have a clue...L... May 20 2003, 02:15 PM
Rob Ways I will reinstall the hangar bolts and diagnose the... May 20 2003, 11:18 PM![]() ![]() |
Lo-Fi Version | Time is now: 29th April 2026 - 05:06 PM |
