mb911 |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,883 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest ![]() ![]() |
I am about to order a bunch of 914-6 soft lines and wanted to see if anyone needed a set at a great price.
The 3 soft lines that work for a stock 914-6 $285 shipped Same as above but all 30mm fittings for larger scavange line $300 shipped.. I believe I am cheaper then anyone on these and they are cohline brand. |
porbmw |
Senior Member ![]() ![]() ![]() Group: Members Posts: 811 Joined: 10-September 08 From: Vancouver, B.C. Member No.: 9,534 Region Association: None ![]() ![]() |
Hi Ben
I would be in for a set! Paul |
amfab |
Member ![]() ![]() Group: Members Posts: 393 Joined: 17-May 16 From: Los Angeles Member No.: 20,004 Region Association: None ![]() ![]() |
I am gonna have to ask for a little technical and economic advice on this one.
I don't know what I am doing oil line-wise with my 3.2 conversion. By that I mean I don't fully understand the routing and what I need to make it work. I have the motor, I have your tank, but the soft lines to which you refer— are these something I will need regardless of my cooler set up (which I have not figured out yet?). And the economic advice: since I am at least a year out from getting the engine in—is the discount on these significant enough to warrant buying them this far in advance? Thanks as always for the help, -Andrew |
Lo-Fi Version | Time is now: 10th June 2024 - 12:21 PM |
