> 123 Distributor group buy (Feb 2019), *** 10% discount, extended to March 24th ***
mobymutt
post Feb 11 2019, 01:57 PM
Ed at Ignition123USA has kindly agreed to give us a discounted price again this year.
Here is his PM to me:
"Hi Matt
Sure we can do a group buy.
I will set up the code 914GB19
It will give you 5% off
If it reaches 10 customers you will be refunded the additional 5%
I will run it for a month.
Hope this helps
Ed "
We've got 10+ orders already through the group buy, so everyone gets 10% off! Thanks to everyone who jumped on board (or off the cliff, or over the fence)!
Selection info from last year's thread:
914 models are available in the following configurations:
1. Hardcoded advance curves with no vacuum, no bluetooth, with no output for D-Jet. Will work with engines that have carbs, L-Jet or aftermarket FI. Will not work with D-Jet.
2. Hardcoded advance curves with vacuum, no bluetooth, with no output for D-Jet Will work with engines that have carbs, L-Jet or aftermarket FI. Will not work with D-Jet.
3. Hardcoded advance curves with no vacuum, no bluetooth, with output for D-Jet This is the unit to choose for stock D-Jet users.
4. Custom bluetooth tunable advance curves with vacuum, with bluetooth, with no output for D-Jet. This is the best unit for carbs, L-Jet, aftermarket FI
5. Custom laptop tunable advance curves with vacuum, no bluetooth, with no output for D-Jet. Will work with engines that have carbs, L-Jet or aftermarket FI. Will not work with D-Jet.
Thanks!
BeatNavy
post Feb 13 2019, 01:54 PM
They recommend using a new coil. In theory, you should not have to if yours is serviceable, but it is recommended.
There is good info in this thread (or specifically at this post: http://www.914world.com/bbs2/index.php?s=&...&p=2545698)
Also, spacer comes with the unit. You don't have to purchase separately.
These things can be slightly tricky to set up initially, but once you've got 'em they are rock solid.
mobymutt   123 Distributor group buy (Feb 2019)   Feb 11 2019, 01:57 PM
Beebo Kanelle   Which model is the correct one for '74 2.0 w/ ...   Feb 11 2019, 02:17 PM
mobymutt   Which model is the correct one for '74 2.0 w/...   Feb 11 2019, 02:28 PM
914_teener   Which model is the correct one for '74 2.0 w/...   Feb 11 2019, 02:36 PM
123ignitionusa   [quote name='Beebo Kanelle' date='Feb ...   Feb 11 2019, 07:31 PM
HansJan   Ed, I just ordered mine (Order #1769). But the ch...   Feb 13 2019, 06:46 PM
123ignitionusa   Yes I will cover that for you. The GB is now at 6...   Feb 13 2019, 11:28 PM
914_teener   Ed at Ignition123USA has kindly agreed to give us...   Feb 11 2019, 02:19 PM
914Sixer   Tried to order and discount does NOT work. No ans...   Feb 11 2019, 02:29 PM
mobymutt   Tried to order and discount does NOT work. No an...   Feb 11 2019, 02:42 PM
mmichalik   Tried to order and discount does NOT work. No a...   Feb 11 2019, 06:14 PM
123ignitionusa   Tried to order and discount does NOT work. No an...   Feb 11 2019, 07:48 PM
Amphicar770   Hmm, will be interesting to see if this gets 10 ta...   Feb 12 2019, 08:24 AM
mobymutt   Hmm, will be interesting to see if this gets 10 t...   Feb 12 2019, 09:01 AM
Amphicar770   Hmm, will be interesting to see if this gets 10 ...   Feb 12 2019, 11:13 AM
mobymutt   [quote name='mobymutt' post='2688491' date='Feb 1...   Feb 12 2019, 11:17 AM
Amphicar770   [quote name='mobymutt' post='2688491' date='Feb ...   Feb 12 2019, 11:25 PM
mmichalik   Just ordered mine. So, there's at least one c...   Feb 12 2019, 02:30 PM
123ignitionusa   Gentlemen Count is two. Additionally if someone o...   Feb 12 2019, 03:36 PM
mobymutt   My order is placed. 3 down, 7 to go!   Feb 12 2019, 08:23 PM
914Sixer   Ordered mine this morning.   Feb 12 2019, 09:13 PM
HansJan   Looking to purchase the Bluetooth model, because t...   Feb 12 2019, 09:34 PM
mobymutt   Looking to purchase the Bluetooth model, because ...   Feb 13 2019, 01:32 PM
jesse7flying   Just ordered mine this afternoon.   Feb 13 2019, 01:30 PM
BeatNavy   They recommend using a new coil. In theory, you s...   Feb 13 2019, 01:54 PM
914_teener   They recommend using a new coil. In theory, you ...   Feb 13 2019, 03:41 PM
davealden223   I'm on the list now. Dave   Feb 13 2019, 02:45 PM
Amphicar770   I just ordered mine. :beer2:   Feb 13 2019, 05:38 PM
michael7810   I’m leaning towards getting in on this GB but ha...   Feb 14 2019, 06:11 AM
123ignitionusa   Yes with the MSD but you must wire it according th...   Feb 14 2019, 10:08 AM
123ignitionusa   Gentlemen Please use the code 914GB19 at checkout....   Feb 14 2019, 10:13 AM
mobymutt   3 more to go to get the 10% discount! If you...   Feb 15 2019, 08:45 AM
mmichalik   3 more to go to get the 10% discount! If you...   Feb 15 2019, 09:10 AM
Porschef   RE: 123 Distributor group buy (Feb 2019)   Feb 15 2019, 12:42 PM
mobymutt   That's a cliff, not a fence. But still, there...   Feb 15 2019, 12:47 PM
914_teener   Here is the bottom of the cliff:   Feb 15 2019, 01:13 PM
Porschef   “What do you mean, you’re still thinkin...   Feb 15 2019, 12:48 PM
mobymutt   Don't get stuck.   Feb 15 2019, 01:05 PM
Porschef   Ok, I’m in... :Qarl: I’ll place the order thi...   Feb 15 2019, 01:43 PM
Amphicar770   Now someone needs to do a write up of install with...   Feb 15 2019, 06:21 PM
mobymutt   Now someone needs to do a write up of install wit...   Feb 15 2019, 07:57 PM
Amphicar770   Now someone needs to do a write up of install wi...   Feb 15 2019, 08:42 PM
mobymutt   @beebo kanelle :poke: Wanna be #9? (I don't...   Feb 15 2019, 09:10 PM
mmichalik   I got my Bluetooth distributor today. Gonna put i...   Feb 16 2019, 12:48 AM
mobymutt   I got my Bluetooth distributor today. Gonna put ...   Feb 16 2019, 11:00 AM
Porschef   Ok. Head, legs, arse, etc. officially on the other...   Feb 16 2019, 07:51 AM
914Sixer   :D Mine is here   Feb 16 2019, 03:24 PM
mobymutt   I'm jealous, I have to make a trip across the ...   Feb 16 2019, 10:51 PM
Amphicar770   Mine arrived as well. BTW, can I still use the re...   Feb 16 2019, 04:54 PM
HansJan   Mine arrived today as well. Will have to wait a w...   Feb 16 2019, 05:43 PM
jsaum   I made a quick sale today on some extra parts so I...   Feb 16 2019, 06:01 PM
michael7810   Just ordered...add me as #9. Jsaum can have the ho...   Feb 16 2019, 06:36 PM
Beebo Kanelle   Done!   Feb 16 2019, 07:58 PM
jsaum   Ok just placed my order so I should be #10. Can’...   Feb 16 2019, 07:59 PM
Ron65   Ok just placed my order so I should be #10. Can...   Feb 16 2019, 08:59 PM
Porschef   Ok just placed my order so I should be #10. Can...   Feb 16 2019, 09:42 PM
123ignitionusa   Ok Guys Way to Go! :trophy: :trophy: Officia...   Feb 16 2019, 10:08 PM
settador   Hi Folks, I'll order one, or perhaps two, on...   Feb 17 2019, 09:04 AM
123ignitionusa   This looks like as good a place as any to add a fe...   Feb 17 2019, 05:45 PM
HansJan   This looks like as good a place as any to add a f...   Mar 21 2019, 04:08 PM
jesse7flying   Got mine yesterday and my 10% refund today. Thank...   Feb 17 2019, 10:34 AM
914Sixer   Checked my mail this morning and I had the 10% ref...   Feb 17 2019, 10:50 AM
Amphicar770   Got my dizzy and my refund as well. Always a pleas...   Feb 17 2019, 11:12 AM
123ignitionusa   Just an update for the 914 World on the GB. All re...   Feb 17 2019, 05:33 PM
mmichalik   I got my 5% refund for a total of 10% off. Thanks...   Feb 18 2019, 05:59 PM
123ignitionusa   I got my 5% refund for a total of 10% off. Thank...   Feb 19 2019, 08:03 AM
settador   Thanks Ed, The conversation yesterday re. vacuum ...   Feb 19 2019, 08:24 AM
Prorallye   Will order one later today.   Feb 19 2019, 08:52 AM
HansJan   Installation video part 1 and 2 https://youtu.be/...   Feb 19 2019, 09:35 PM
buck toenges   Nice to see but I felt I was watching an episode o...   Feb 20 2019, 03:48 PM
Porschef   Yep, it’s as easy as “Einz, Zwei, Drei!”...   Feb 20 2019, 08:05 PM
123ignitionusa   Hey Guys and Gals All the orders are in the mail 2...   Feb 25 2019, 10:54 PM
Porschef   Thanks Ed. Looking forward to it. Glad I didn’...   Feb 26 2019, 05:15 AM
Ron65   Received my 123 today! Thank you to Ed at 123...   Feb 28 2019, 09:29 AM
123ignitionusa   Just a bump to remind anyone interested this will ...   Mar 10 2019, 06:12 PM
jim_hoyland   Just a bump to remind anyone interested this will...   Mar 15 2019, 02:58 PM
123ignitionusa   This is a great group of enthusiasts. I will exten...   Mar 17 2019, 06:22 PM
michael7810   Did someone, or could some post a link to an insta...   Mar 11 2019, 01:23 PM
jim_hoyland   Just placed my order; hard to tell whether it went...   Mar 17 2019, 07:04 PM
123ignitionusa   914GB19 Here you go. Just placed my order; hard...   Mar 17 2019, 07:53 PM
jim_hoyland   Tried the code each time too... Tried PP first two...   Mar 17 2019, 08:40 PM
123ignitionusa   Sounds like a Paypal issue. Give them a call. As ...   Mar 18 2019, 08:02 AM
jim_hoyland   Big thanks to Ed at 1-2-3; talked with him directl...   Mar 18 2019, 11:02 AM
settador   The following thread has a very helpful write up r...   Mar 21 2019, 05:37 PM
914_teener   The following thread has a very helpful write up ...   Apr 2 2019, 05:20 PM
914-300Hemi   I know that I missed the group by but after fiddli...   Apr 2 2019, 03:49 PM
michael7810   I installed the Bluetooth unit on my 1911cc, webca...   Apr 6 2019, 04:05 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 09:31 AM
