Fuel Tank Frustration!, Tank is Sitting too High |
914_7T3 |
Feb 14 2019, 11:57 PM
Please forgive me, I'm new to all of this! Group: Members Posts: 1,853 Joined: 3-April 17 From: Los Angeles, CA Member No.: 20,991 Region Association: Southern California |
Does anyone have info or photos on the correct placement of the fuel tank pads for the tank to be positioned correctly.
My shop is having trouble seating the tank low enough for a correct installation. How much lower do the bumper pads need to be to make this work and what is the best way to install them? Here are some pics of how it sits presently. Advice is appreciated! |
sb914 |
Feb 15 2019, 06:05 AM
Surf Guru Group: Members Posts: 4,316 Joined: 25-November 12 From: Brookings,Oregon Member No.: 15,191 Region Association: Southern California |
use Tape at the top of the rubber to hold it in place,then remove tape once the tanks in place. The rubber sits about 1 inch from the top !
914_7T3 |
Feb 15 2019, 02:14 PM
use Tape at the top of the rubber to hold it in place,then remove tape once the tanks in place. The rubber sits about 1 inch from the top ! @sb914 an inch from the top of the smooth edge of the tank itself or the top of the edge that slots into the groove of the pad? (IMG:style_emoticons/default/confused24.gif) |
sb914 |
Feb 15 2019, 04:43 PM
use Tape at the top of the rubber to hold it in place,then remove tape once the tanks in place. The rubber sits about 1 inch from the top ! @sb914 an inch from the top of the smooth edge of the tank itself or the top of the edge that slots into the groove of the pad? (IMG:style_emoticons/default/confused24.gif) Here’s where mine sits. It’s about a inch from the top of the shock tower. It’s also a good idea to lengthen the fuel line for future removal. Makes it way easier with the extra length of hose . |
Lo-Fi Version | Time is now: 9th June 2024 - 02:14 AM |
