| mobymutt |
Feb 11 2019, 01:57 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 553 Joined: 16-December 13 From: Kingston, Ontario, Canada Member No.: 16,770 Region Association: Canada |
Ed at Ignition123USA has kindly agreed to give us a discounted price again this year.
Here is his PM to me: "Hi Matt Sure we can do a group buy. I will set up the code 914GB19 It will give you 5% off If it reaches 10 customers you will be refunded the additional 5% I will run it for a month. Hope this helps Ed " We've got 10+ orders already through the group buy, so everyone gets 10% off! Thanks to everyone who jumped on board (or off the cliff, or over the fence)! Selection info from last year's thread: 914 models are available in the following configurations: 1. Hardcoded advance curves with no vacuum, no bluetooth, with no output for D-Jet. Will work with engines that have carbs, L-Jet or aftermarket FI. Will not work with D-Jet. 2. Hardcoded advance curves with vacuum, no bluetooth, with no output for D-Jet Will work with engines that have carbs, L-Jet or aftermarket FI. Will not work with D-Jet. 3. Hardcoded advance curves with no vacuum, no bluetooth, with output for D-Jet This is the unit to choose for stock D-Jet users. 4. Custom bluetooth tunable advance curves with vacuum, with bluetooth, with no output for D-Jet. This is the best unit for carbs, L-Jet, aftermarket FI 5. Custom laptop tunable advance curves with vacuum, no bluetooth, with no output for D-Jet. Will work with engines that have carbs, L-Jet or aftermarket FI. Will not work with D-Jet. Thanks! |
| settador |
Feb 17 2019, 09:04 AM
Newbie ![]() Group: Members Posts: 31 Joined: 16-May 05 From: Lee, NH Member No.: 4,086 Region Association: None
Hi Folks,
I'll order one, or perhaps two, on Monday. I do have some questions for you all, however, because I'm not entirely sure which one(s). Some of the 356 guys think these are terrific too, and say the vacuum model is best. If I recall correctly, the vacuum line comes off the insulator between the carb and manifold below the throttle plate like some year 912s from the factory, implying initial advance is actuated by a decrease in manifold pressure. In other words, the vacuum line retards the timing when in full force, yes? I ask because I intend to build a 2056 out of a GA motor I have to replace my tired 1.8. I also have a pair of Weber 40s I intend to use for that build. If I go with a vacuum model, are there insulators/spacers with vacuum ports available for Weber 40s? If not, has anyone made their own? How great is the performance advantage of the vacuum model over the mechanical only model? I imagine the initial response off idle may be significant. I've read through the previous threads, but I'm still not entirely clear. Thanks, Dan |
mobymutt 123 Distributor group buy (Feb 2019) Feb 11 2019, 01:57 PM
Beebo Kanelle Which model is the correct one for '74 2.0 w/ ... Feb 11 2019, 02:17 PM
mobymutt
Which model is the correct one for '74 2.0 w/... Feb 11 2019, 02:28 PM
914_teener
Which model is the correct one for '74 2.0 w/... Feb 11 2019, 02:36 PM
123ignitionusa [quote name='Beebo Kanelle' date='Feb ... Feb 11 2019, 07:31 PM
HansJan Ed,
I just ordered mine (Order #1769).
But the ch... Feb 13 2019, 06:46 PM
123ignitionusa Yes I will cover that for you. The GB is now at 6... Feb 13 2019, 11:28 PM
914_teener
Ed at Ignition123USA has kindly agreed to give us... Feb 11 2019, 02:19 PM
914Sixer Tried to order and discount does NOT work. No ans... Feb 11 2019, 02:29 PM
mobymutt
Tried to order and discount does NOT work. No an... Feb 11 2019, 02:42 PM
mmichalik
Tried to order and discount does NOT work. No a... Feb 11 2019, 06:14 PM
123ignitionusa
Tried to order and discount does NOT work. No an... Feb 11 2019, 07:48 PM
Amphicar770 Hmm, will be interesting to see if this gets 10 ta... Feb 12 2019, 08:24 AM
mobymutt
Hmm, will be interesting to see if this gets 10 t... Feb 12 2019, 09:01 AM
Amphicar770
Hmm, will be interesting to see if this gets 10 ... Feb 12 2019, 11:13 AM
mobymutt
[quote name='mobymutt' post='2688491' date='Feb 1... Feb 12 2019, 11:17 AM
Amphicar770
[quote name='mobymutt' post='2688491' date='Feb ... Feb 12 2019, 11:25 PM
mmichalik Just ordered mine. So, there's at least one c... Feb 12 2019, 02:30 PM
123ignitionusa Gentlemen
Count is two.
Additionally if someone o... Feb 12 2019, 03:36 PM
mobymutt My order is placed. 3 down, 7 to go! Feb 12 2019, 08:23 PM
914Sixer Ordered mine this morning. Feb 12 2019, 09:13 PM
HansJan Looking to purchase the Bluetooth model, because t... Feb 12 2019, 09:34 PM
mobymutt
Looking to purchase the Bluetooth model, because ... Feb 13 2019, 01:32 PM
jesse7flying Just ordered mine this afternoon. Feb 13 2019, 01:30 PM
BeatNavy They recommend using a new coil. In theory, you s... Feb 13 2019, 01:54 PM
914_teener
They recommend using a new coil. In theory, you ... Feb 13 2019, 03:41 PM
davealden223 I'm on the list now.
Dave Feb 13 2019, 02:45 PM
Amphicar770 I just ordered mine. :beer2: Feb 13 2019, 05:38 PM
michael7810 I’m leaning towards getting in on this GB but ha... Feb 14 2019, 06:11 AM
123ignitionusa Yes with the MSD but you must wire it according th... Feb 14 2019, 10:08 AM
123ignitionusa Gentlemen Please use the code 914GB19 at checkout.... Feb 14 2019, 10:13 AM
mobymutt 3 more to go to get the 10% discount! If you... Feb 15 2019, 08:45 AM
mmichalik
3 more to go to get the 10% discount! If you... Feb 15 2019, 09:10 AM
Porschef RE: 123 Distributor group buy (Feb 2019) Feb 15 2019, 12:42 PM
mobymutt That's a cliff, not a fence. But still, there... Feb 15 2019, 12:47 PM
914_teener
Here is the bottom of the cliff:
Feb 15 2019, 01:13 PM
Porschef
“What do you mean, you’re still thinkin... Feb 15 2019, 12:48 PM
mobymutt Don't get stuck.
Feb 15 2019, 01:05 PM
Porschef Ok, I’m in... :Qarl: I’ll place the order thi... Feb 15 2019, 01:43 PM
Amphicar770 Now someone needs to do a write up of install with... Feb 15 2019, 06:21 PM
mobymutt
Now someone needs to do a write up of install wit... Feb 15 2019, 07:57 PM
Amphicar770
Now someone needs to do a write up of install wi... Feb 15 2019, 08:42 PM
mobymutt @beebo kanelle
:poke:
Wanna be #9?
(I don't... Feb 15 2019, 09:10 PM
mmichalik I got my Bluetooth distributor today.
Gonna put i... Feb 16 2019, 12:48 AM
mobymutt
Gonna put ... Feb 16 2019, 11:00 AM
Porschef Ok. Head, legs, arse, etc. officially on the other... Feb 16 2019, 07:51 AM
914Sixer :D Mine is here Feb 16 2019, 03:24 PM
mobymutt I'm jealous, I have to make a trip across the ... Feb 16 2019, 10:51 PM
Amphicar770 Mine arrived as well. BTW, can I still use the re... Feb 16 2019, 04:54 PM
HansJan Mine arrived today as well.
Will have to wait a w... Feb 16 2019, 05:43 PM
jsaum I made a quick sale today on some extra parts so I... Feb 16 2019, 06:01 PM
michael7810 Just ordered...add me as #9. Jsaum can have the ho... Feb 16 2019, 06:36 PM
Beebo Kanelle Done! Feb 16 2019, 07:58 PM
jsaum Ok just placed my order so I should be #10. Can’... Feb 16 2019, 07:59 PM
Ron65
Ok just placed my order so I should be #10. Can... Feb 16 2019, 08:59 PM
Porschef
Ok just placed my order so I should be #10. Can... Feb 16 2019, 09:42 PM
123ignitionusa Ok Guys
Way to Go! :trophy: :trophy: Officia... Feb 16 2019, 10:08 PM
123ignitionusa This looks like as good a place as any to add a fe... Feb 17 2019, 05:45 PM
HansJan
This looks like as good a place as any to add a f... Mar 21 2019, 04:08 PM
jesse7flying Got mine yesterday and my 10% refund today. Thank... Feb 17 2019, 10:34 AM
914Sixer Checked my mail this morning and I had the 10% ref... Feb 17 2019, 10:50 AM
Amphicar770 Got my dizzy and my refund as well. Always a pleas... Feb 17 2019, 11:12 AM
123ignitionusa Just an update for the 914 World on the GB.
All re... Feb 17 2019, 05:33 PM
mmichalik I got my 5% refund for a total of 10% off. Thanks... Feb 18 2019, 05:59 PM
123ignitionusa
I got my 5% refund for a total of 10% off. Thank... Feb 19 2019, 08:03 AM
settador Thanks Ed,
The conversation yesterday re. vacuum ... Feb 19 2019, 08:24 AM
Prorallye Will order one later today. Feb 19 2019, 08:52 AM
HansJan Installation video part 1 and 2
https://youtu.be/... Feb 19 2019, 09:35 PM
buck toenges Nice to see but I felt I was watching an episode o... Feb 20 2019, 03:48 PM
Porschef Yep, it’s as easy as “Einz, Zwei, Drei!”... Feb 20 2019, 08:05 PM
123ignitionusa Hey Guys and Gals
All the orders are in the mail 2... Feb 25 2019, 10:54 PM
Porschef Thanks Ed. Looking forward to it.
Glad I didn’... Feb 26 2019, 05:15 AM
Ron65 Received my 123 today! Thank you to Ed at 123... Feb 28 2019, 09:29 AM
123ignitionusa Just a bump to remind anyone interested this will ... Mar 10 2019, 06:12 PM
jim_hoyland
Just a bump to remind anyone interested this will... Mar 15 2019, 02:58 PM
123ignitionusa This is a great group of enthusiasts. I will exten... Mar 17 2019, 06:22 PM
michael7810 Did someone, or could some post a link to an insta... Mar 11 2019, 01:23 PM
jim_hoyland Just placed my order; hard to tell whether it went... Mar 17 2019, 07:04 PM
123ignitionusa 914GB19
Here you go.
Just placed my order; hard... Mar 17 2019, 07:53 PM
jim_hoyland Tried the code each time too...
Tried PP first two... Mar 17 2019, 08:40 PM
123ignitionusa Sounds like a Paypal issue. Give them a call.
As ... Mar 18 2019, 08:02 AM
jim_hoyland Big thanks to Ed at 1-2-3; talked with him directl... Mar 18 2019, 11:02 AM
settador The following thread has a very helpful write up r... Mar 21 2019, 05:37 PM
914_teener
The following thread has a very helpful write up ... Apr 2 2019, 05:20 PM
914-300Hemi I know that I missed the group by but after fiddli... Apr 2 2019, 03:49 PM
michael7810 I installed the Bluetooth unit on my 1911cc, webca... Apr 6 2019, 04:05 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 09:23 AM |
