> A few disconnected parts
isdyl
post Feb 9 2019, 07:10 AM
Region Association: England
Hi - so I'm just preparing for my maiden voyage - the car must have been off the road for at least 10 years judging by the rust in the floor when I got it in June. I've changed the fan belt this morning, but there are a few thingsI saw that I think need tidying. Its got a mid mounted progressive weber (yes I know), and there looks to be a port on each side near where the headers meet the tin - should some pipes be connected to these please? Also in one photo showing the port on the passenger side there is a wire coming out of the tin with a female spade connector - you can see it in the photo. There is also a green with red trace wire coming out of the loom near the distributor which isn't connected to anything.
The car runs, but not well. Not sure how far I will get down the road!
Thanks, Dylan
Spoke
post Feb 19 2019, 09:29 AM
Jerry
If you don't want to do FI, then find a set of dual carbs. You can dick around all day with that single carb and it will still run poorly. Going WOT will generally just produce much black smoke and no more power.
I found a set of used dual Weber carbs. They came on a 1.8L engine with SSHE all for $500.
isdyl
post Feb 19 2019, 11:36 AM
Yes a set of dual Weber carbs would be the more economical solution in the UK, but even a pair of carbs sell for £450 and then there's inlet manifolds, filters and linkage to purchase. Nothing like that is cheap over here. Before I do that I'm going to give the single progressive a chance as it's there and free. I actually picked up another one on eBay for £20 for parts.
QUOTE(Spoke @ Feb 19 2019, 09:29 AM) *
isdyl   A few disconnected parts   Feb 9 2019, 07:10 AM
ClayPerrine   Those two open ports are cylinder head vents. You ...   Feb 9 2019, 08:40 AM
isdyl   Thanks very much! Those two open ports are c...   Feb 9 2019, 09:05 AM
isdyl   Those two open ports are cylinder head vents. You...   Feb 13 2020, 12:33 PM
isdyl   Those two open ports are cylinder head vents. Yo...   Feb 14 2020, 07:28 AM
ClayPerrine   [quote name='isdyl' post='2785648' date='Feb 13 2...   Feb 14 2020, 08:13 AM
isdyl   [quote name='isdyl' post='2785648' date='Feb 13 ...   Feb 14 2020, 11:14 AM
mgphoto   In your first photo it looks like your accelerator...   Feb 9 2019, 09:23 AM
isdyl   Yes, it does look a bit of a mess I admit. The acc...   Feb 18 2019, 11:22 AM
mgphoto   Yes, it does look a bit of a mess I admit. The ac...   Feb 18 2019, 01:30 PM
isdyl   Ok thanks - so just the spring at the carb or thro...   Feb 18 2019, 03:51 PM
Rob-O   With the center mounted carb there is usually a sp...   Feb 18 2019, 07:22 PM
isdyl   Thanks - I would definitely consider FI but there ...   Feb 19 2019, 01:50 AM
ClayPerrine   Thanks - I would definitely consider FI but there...   Feb 19 2019, 06:47 AM
isdyl   They don't check emissions on vehicles this ol...   Feb 19 2019, 07:35 AM
PanelBilly   You might check that the throttle wire isn’t wra...   Feb 19 2019, 09:24 AM
isdyl   Thanks, I'll check that. You might check tha...   Feb 19 2019, 11:27 AM
Spoke   If you don't want to do FI, then find a set of...   Feb 19 2019, 09:29 AM
isdyl   Yes a set of dual Weber carbs would be the more ec...   Feb 19 2019, 11:36 AM
mgphoto   '73 model year, the angle of the spark plug sa...   Feb 19 2019, 12:22 PM
isdyl   Thanks for the info. D-jetronic is good news as I ...   Feb 19 2019, 02:29 PM
isdyl   Hi - I'm just eventually starting to fit the d...   Jan 16 2020, 04:16 AM
Spoke   Hi - I'm just eventually starting to fit the ...   Jan 16 2020, 04:49 AM
isdyl   Thanks - that's a great photo to help me get e...   Jan 16 2020, 06:28 AM
isdyl   Hi! That photo has been really helpful and the...   Feb 11 2020, 01:14 PM
rjames   Last pic is of the decel valve. Mounted on the sa...   Feb 11 2020, 06:13 PM
isdyl   Last pic is of the decel valve. Mounted on the s...   Feb 12 2020, 01:16 AM
cwpeden   Check this thread for hoses. I think you have AAR ...   Feb 14 2020, 08:42 AM
isdyl   Check this thread for hoses. I think you have AAR...   Feb 14 2020, 11:27 AM
- Lo-Fi Version Time is now: 11th November 2026 - 02:30 PM
