1974 2.0 in a 73’ 1.7? |
MiniStevieG |
Feb 20 2019, 08:18 PM
Member Group: Members Posts: 179 Joined: 25-January 19 From: Dallas, TX Member No.: 22,827 Region Association: Southwest Region |
Found a rebuilt 2.0. Engine code is a GA so if my research proves accurate this is actually a 74’ engine. Confirmed 3 bolt pattern on the intake heads. Stoked!! I’m curious if this will drop right into my 73’ that’s currently a 1.7 and what I might be in for with this? Headers and heat exchangers? Just a note: per the owner that rebuilt the engine it hasn’t been run since the rebuild so needless to say I need to learn more about what all needs to happen prior to dropping this in and firing it up. Considering taking it to Mayo Performance in Dallas to handle the swap but I’m also a fast learner and eager to do it myself.
Thanks!! |
bbrock |
Feb 20 2019, 09:25 PM
If it comes with the engine tins, I think it should plug right in. Only thing I can think of is that you'll need to reroute your accelerator cable for the carbs. I'd also make sure it was rebuilt with a carb cam to work well with the Webers.
You will love that engine. BTW, does your car have sway bars? I think at least a front bar is a must-have to get the joy out of that engine. |
MiniStevieG |
Feb 20 2019, 09:52 PM
If it comes with the engine tins, I think it should plug right in. Only thing I can think of is that you'll need to reroute your accelerator cable for the carbs. I'd also make sure it was rebuilt with a carb cam to work well with the Webers. You will love that engine. BTW, does your car have sway bars? I think at least a front bar is a must-have to get the joy out of that engine. Mine does not have sway bars. |
Lo-Fi Version | Time is now: 9th June 2024 - 10:29 PM |
