ok advice on starting an old motor, ok engines in...fixed starter problem |
DrifterJay |
Nov 25 2004, 02:23 AM
I break stuff... Group: Members Posts: 1,034 Joined: 25-May 03 From: Oceanside, California Member No.: 737 Region Association: None |
ok guys, I need help...I want to wake up the neighbors. I fixed my whole starter problem (IMG:style_emoticons/default/smile.gif) . Engine is in, everything is plugged, I got fuel going, all the good shit. I want to start her...I turned her over a couple of times...nothing...no burbles nada... Moved the dizzy a bit to see if I get any response...Nothing....So I move the plugs two slots over to see if it is possibly one eighty out....No difference, in fact, the engine pauses every two seconds when I turn it over. So I dont think that is the issue...Any other thoughts or ideas...could the engine possibly be flooded? too much fuel? Should I disconnect the fuel pump from the coil and try again for a little while...See if it will fire without flooding it, then reconnect the pump before it dies...Any ideas...Anyone out there? Help me....I am soo close... (IMG:style_emoticons/default/smile.gif)
DrifterJay |
Nov 25 2004, 03:01 PM
engine was one eighty out....fired her up...forgot to put a valve cover on...about a half quart of oil on the ground and the heat exchangers.... (IMG:style_emoticons/default/biggrin.gif) but I dont care...the bitch runs....need to go smoke....damnit Thanksgiving is getting in the way...lol...could be driving in two hours....axles not hooked up, shift linkage not in...and etc....well tonight maybe I will wake the neighbors when I get back.... (IMG:style_emoticons/default/aktion035.gif)
Lo-Fi Version | Time is now: 7th June 2024 - 10:56 AM |
