StarBear |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,913 Joined: 2-September 09 From: NJ Member No.: 10,753 Region Association: North East States ![]() ![]() |
A real quickie - trying to remove my ECU and the wire harness doesn't disconnect from the ECU. There's a little black screw at the top of the black sheath covering the harness connection. OK to remove?
Been doing this long enough to have learned not to unscrew things I don't know anything about! Got the ECU and cradle unbolted, but not enough room (engine in place) to remove with the harness connected. Thanks! |
Olympic 914 |
![]() ![]() ![]() Group: Members Posts: 1,676 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States ![]() ![]() |
disconnect the cable clamp at the bottom of the ECU and swing it out of the way then the black plastic cover slides down. inside there should be a white plastic handle to pull and unplug the wiring harness.
It may be real stiff to slide down. The screw in the side of the black plastic should attach to the ECU carrier. it just prevents it from swinging on the top mounts. and does not attach to anything inside. |
Lo-Fi Version | Time is now: 10th June 2024 - 03:51 PM |
