Identifiy these parts, Part ID |
Cornerlot |
Feb 23 2019, 10:28 PM
Member Group: Members Posts: 89 Joined: 4-June 16 From: New Braunfels, TX Member No.: 20,070 Region Association: Southwest Region |
Olympic 914 |
Feb 24 2019, 09:08 AM
Group: Members Posts: 1,676 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
Clutch cable end.
Looks similar but not it. Don't know what the black plastic part is but the clutch cable end is made of metal and shaped differently. I wouldn't use a plastic part there. You could end up stuck somewhere with no clutch Although the DAPO did use a big wingnut instead of the correct part and it worked for a while. Glad I found that before it stuck me. |
bbrock |
Feb 24 2019, 10:20 AM
Clutch cable end. Looks similar but not it. Don't know what the black plastic part is but the clutch cable end is made of metal and shaped differently. I wouldn't use a plastic part there. You could end up stuck somewhere with no clutch Although the DAPO did use a big wingnut instead of the correct part and it worked for a while. Glad I found that before it stuck me. The original clutch trunions were black plastic like the part in question. That is definitely what that part is. Most have been replaced with metal because the plastic ones break and leave you stranded just like you predict. Ask me how I know... |
Dave_Darling |
Feb 25 2019, 05:36 PM
The original clutch trunions were black plastic like the part in question. That is definitely what that part is. Most have been replaced with metal because the plastic ones break and leave you stranded just like you predict. Ask me how I know... Absolutely! The metal one is from a 911, not a 914. Notice that the plastic is longer than the metal trunnion; this is one of the reasons that you need a spacer on the cable when you use the metal trunnion. --DD |
Lo-Fi Version | Time is now: 9th June 2024 - 07:23 PM |
