1974 2.0 in a 73’ 1.7? |
MiniStevieG |
Feb 20 2019, 08:18 PM
Member Group: Members Posts: 179 Joined: 25-January 19 From: Dallas, TX Member No.: 22,827 Region Association: Southwest Region |
Found a rebuilt 2.0. Engine code is a GA so if my research proves accurate this is actually a 74’ engine. Confirmed 3 bolt pattern on the intake heads. Stoked!! I’m curious if this will drop right into my 73’ that’s currently a 1.7 and what I might be in for with this? Headers and heat exchangers? Just a note: per the owner that rebuilt the engine it hasn’t been run since the rebuild so needless to say I need to learn more about what all needs to happen prior to dropping this in and firing it up. Considering taking it to Mayo Performance in Dallas to handle the swap but I’m also a fast learner and eager to do it myself.
Thanks!! |
rhodyguy |
Mar 6 2019, 10:59 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,093 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
If you don't plan on refurbing the AC, that's a bunch of work added to the list. Best to make a comprehensive list of ALL of the rust and other chassis/body repairs. Parts and labor is going to be $$$$. I would not buy anymore fixers at this point.
MiniStevieG |
Mar 6 2019, 11:17 AM
If you don't plan on refurbing the AC, that's a bunch of work added to the list. Best to make a comprehensive list of ALL of the rust and other chassis/body repairs. Parts and labor is going to be $$$$. I would not buy anymore fixers at this point. Thanks! Yeah no real plans to address the AC as the list will be prioritized to make sure everything else is in order. |
Lo-Fi Version | Time is now: 10th June 2024 - 12:10 AM |
