'6 flywheel, 2.0 P&C set "Tuna can" sump |
914ltd |
Feb 12 2019, 02:39 PM
Member Group: Members Posts: 239 Joined: 18-April 03 From: Peoria, IL Member No.: 581 Region Association: None |
Some interesting odds and ends:
Koni rear shocks, hand tested, even resistance, no air bubbles. $60 SOLD Heater blower for 73-73. tested, includes original clamp and rubber pad. $35 Bursch for 1.7 and 1.8. good, no muffler, add what you want or a straight pipe. $75 SOLD Pair of 1.7 and 1.8 SSI heats. Leak tested, muffler flange getting thin but still OK. $225. pair SOLD Flywheel, 911 1965 thru 1969 and 914/6. Nice friction surface, 2mm wear on the starter ring gear. Porsche allows 2mm cut from this surface for clean up. $175. Set of stock, US 2.0 pistons and cylinders. Minimal wear, these are in great condition for used. Marked as paired sets 1 thru 4. Clean, ring and use. $150 Weltmeister deep sump (tuna can) $45 Small flat rate ship, $7.90 All parts plus ship from 61611. Thanks, Brad Attached image(s) |
914ltd |
Mar 13 2019, 10:24 AM
911 flywheel, tuna can still available |
Lo-Fi Version | Time is now: 28th May 2024 - 05:43 PM |
