FS:Complete 911 Carrera Ft Suspension - Side to Side, Everything as new-- Sold to Joe Proper |
burton73 |
Mar 20 2019, 04:18 PM
burton73 Group: Members Posts: 3,552 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
I bought this from TOOLGUY Dave a little over a year ago.
Each piece has a concourse finish. I can reshoot some of the pictures if these are not clear enough Bob B I have decided to sell my 70 914 that I was going to build a high HP conversation out of and am selling these suspension parts. This is a complete 911 SC/Carrera front suspension. All rebuilt or new except the used KONI’s that are super clean. Read all that Dave - Toolguy did to this set up. This is an unbolt your old set up and bolt this new set up in and you have a fresh concourse finish Carrera front with new or rebuilt parts just like it came out of the factory in an 80s Carrera. I put a used set up in a 74 914 that was 5 years old and with fresh parts and the big sway bar you are rocking. Just drop or let’s say lift it in and get a front-end alignment. The cost and time to do this in this way is huge. Save your time and money. If changing to 5 lugs on car rear I have a 5-lug rear hub drilled and welded in the right way. $250 for the rear hubs $2,750. It’s in Inglewood, CA I can ship if need be but it is heavy and would need a proper shipping case built. $100 for that and I am not sure what shipping would be. We would need to work that out. TOOLGUY: Jan 19th 2018 This is a complete 911 SC/Carrera front suspension. . Has 3 1/2 inch A type calipers. Complete, nuts, bolts, the whole works. Everything new or fresh restored as pictured except the used Koni's. Just removed from an undriven restored car. Clean, restored with fresh powder paint and plating. It has new Lemforder Ball Joints. All new wheel bearings and seals with new Porsche brake pad kits. Includes wheel bearing nuts and washer and dust covers. Rotors were turned. Both calipers rebuilt using real ATE kits, with new hard and ATE soft brake lines included. Has OE Porsche factory rubber A arm bushings installed in mounts already pressed on. Struts have new wedge bolts, and strut cartridge nuts. Aluminum cross member with 20 mm sway bar, mounts and bushings. Has 19 mm Porsche torsion bars with caps and adjusters. Only thing you need to provide is the 4 front A arm bolts and the 2 cross-member mount bolts. . they are the same as on a 914-4. And brake fluid. . LUCKY9146: Jan 20th 2018 I know toolguy personally and everything he does is meticulous and thorough. All that came off his concours winning 914 with best of show just this past Sept in San Diego. Took off because he wanted to return the car to completely original. MEPSTEIN:Jan 19th 2018 Its amazing how much time it takes to make the parts look nice and all the little stuff really adds up. [attachmentid=690 512] Attached image(s) |
Lo-Fi Version | Time is now: 10th June 2024 - 04:46 AM |
