FS new master cylinders 19mm $95 |
Mikey914 |
Mar 19 2019, 11:05 PM
The rubber man Group: Members Posts: 12,671 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
So the majority of the master cylinders we've been selling are the easy option, so we have put the non-easy on sale. Just like stock, 19mm master cylinders. It's either this or disassemble, re-machine (for the easy kit), reassemble, and test.
Thanks to all! Mark https://900designs-container.zoeysite.com/1...er-cylinder-2-1 Attached image(s) |
Mikey914 |
Mar 20 2019, 11:47 PM
You are welcome to try to tap the upper ports, but there is the possibility of getting material into unit. We do ours before assembly, and if we were to do this (tap the no tapped versions we made) we would not do it assembled.
It would be easier to just buy the "easy" kit which we have done this already and include the machined nipples and hydraulic hose to splice into the existing lines. |
Specracer |
Mar 21 2019, 05:47 AM
Member Group: Members Posts: 100 Joined: 27-March 17 From: SE Mass Member No.: 20,970 Region Association: None |
Itsnt timing everything, 20 days ago, bought said item for $145...
Lo-Fi Version | Time is now: 23rd May 2024 - 10:21 AM |
