Bezel rings, to freshen up old gauges |
timothy_nd28 |
Mar 20 2019, 12:20 PM
Advanced Member Group: Members Posts: 2,299 Joined: 25-September 07 From: IN Member No.: 8,154 Region Association: Upper MidWest |
I've taken on a project for Mark where I'm repairing a tachometer and upgrading it to a hologram heads up display for his 2 cylinder motorcycle. Well, perhaps not heads up display on this one, but maybe on the next tach he sends me!
During the repairs, I cracked the chrome bezel ring. I think the Veglia rev counter company didn't do a proper annealing process when making these rings, as they are very easy to crack. To my amazement, there are suppliers online that will sell you replacement bezels. After ordering this replacement bezel, I got to talking with the person selling these and asked if he's willing to sell bezel rings for our 914 gauges. He seems very interested, I'm sure he can sell them as original black or chrome plated. The bigger question would be, is there any interest in this? If it was sold in kit form, with new glass lenses? |
Superhawk996 |
Mar 22 2019, 09:19 AM
914 Guru Group: Members Posts: 5,900 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
For those of you that have a lathe, same thing can be done in a large lathe chuck.
My lathe is too small to handle speedo / tach. I've had luck in the past with motorcycle gauges by carefully bending with a larger jewelers screwdriver about 100 times around the bezel periphery. @bbrock may have a slick solution. I think he mentioned that he had swapped plastic lenses for glass and I'm sure he didn't have a pretty machine like this. (IMG:style_emoticons/default/biggrin.gif) |
bbrock |
Mar 22 2019, 09:51 AM
For those of you that have a lathe, same thing can be done in a large lathe chuck. My lathe is too small to handle speedo / tach. I've had luck in the past with motorcycle gauges by carefully bending with a larger jewelers screwdriver about 100 times around the bezel periphery. @bbrock may have a slick solution. I think he mentioned that he had swapped plastic lenses for glass and I'm sure he didn't have a pretty machine like this. (IMG:style_emoticons/default/biggrin.gif) I bought the Bezel-Matic-3000 on ebay for $500 (IMG:style_emoticons/default/biggrin.gif) Of course I didn't use fancy tools but nothing ingenious. I used the same solution as you - small screw driver and patience. Once I got a little bit lifted I then dragged the screw driver under the lip as much as I could in small segments at a time to roll the lip out smoothly. Done carefully, you'll barely be able to see you were in there and that will be only from the back. It doesn't even take that much time. Maybe 10-15 minutes per bezel. Lots of people have done it. |
Lo-Fi Version | Time is now: 9th June 2024 - 09:05 PM |
